p.rodrigues
Where to view transcoding? PC, Smartphone... What is the cable operator?
Well, it's no only codecs problems. Even in MPC HC it does not work. Like 95% of times it does not work. If you see the input bitrate is far away from what I should be getting.
I really don't know hwat's happening. Same channel, same app, only works sometimes.
I have no cable... but on satellite everyone opened through MPC. There is also a small truquer, I do not remember well ... it repairs on the covirement of this:
#EXTM3U
#EXTVLCOPT:http-reconnect=true
#EXTINFrogram=5040,Eleven 4
http://192.168.178.24:8001/1:0:19:1...ht=720?vcodec=h264?aspectratio=2?interlaced=0
You find all about this on the Drag... including tests where I participated.
Why not give a try to Kodi Kodi.tv/download/android and and use the PVR clients enigma client 19.0.0
