Realtek rtl8812au driver for new Vu+ kernel
Hello everybody
I have a Gigablue WLAN Stick-600-Mbit Dual-Band USB Adapter For my Solo2 bought (rtl8812au). Unfortunately I do not get him to run! Can someone help me? I use VTI Image 11. Lg YY Sorry for my bad English
Hello.
Please help with the TP-LINK Archer T4U AC 1300 ver.2 FCC ID TE7T4UV2 wifi adapter on the Vu + Solo2 BH 3.0.3.L receiver
Once connected to the usb port, it is not detected (the diode is off and the wireless LAN setting is not visible). I checked the driver (rtl8812au) over the TS Panel and it is installed. I also tried installing rtl8812au_git-r0-bh0_vusolo2.ipk manually from the first tune of this thread, but I still can not get the device up and running.
Thank you for your advice and apologize, please, my bad English ....
Why image doesn't work with USB Wi-Fi D-Link DWA-125 rev A2?
It also doesn't work with USB Wi-Fi TP-Link 321G
How I can fix it?
I install rt3070_2.5.0.3-r4-bh0_vuuno.ipk but it still doesnt work on me uno 4k
I have bought Meross WiFi USB adapter which I want to use on BlackHole 3.0.4 on Vu Zero. Card is not recognized automatically, and WiFi is not working.
On Windows is recognized as: Realtek RTL8811AU Wireless LAN USB
Here is also link for my adapter, where linux drivers can be downloaded: http://www.meross.com/products/usb_adapters/2.html
When I check over telnet on my Vu Zero, I get following:
root@vuzero:~# lsusb
Bus 001 Device 004: ID 0bda:a811
Bus 001 Device 001: ID 1d6b:0002
Bus 002 Device 001: ID 1d6b:0001
My WiFi USB adapter is -> Bus 001 Device 004: ID 0bda:a811
Do we need add some entry (this ID from above... or something) in to the IPK for RTL8811AU for Blackhole on Vu Zero?
Thank you for quick help / support.
Hi, i hope anyone can help me.
I have until now used a Sweex Wireless 54G Adapter on my vu+duo. Its been ok, but i am now thinking of streaming from the box to a tv and i assume this is a bottleneck.
So today i bought a TP-Link AC450 Wireless Nano UDB Adapter. I plugged it in and hoped for the best. Unfortunately, the box did not like it and could not detect it. It came with some error message that no module something could not be found.
So, do i need to install a new driver? Is the driver available in the BH image somewhere, so that i just need to activate it or does it not exist and or can someone help me out?
I join, I also have some RTL8811AU. (ID 0bda:a811)
with the speed of these little ones we would have good connection.
Driver 8812 is compatible with these because of what I have seen in some pages.
Could someone compile the 8812 for these?
Greetings.
It's included into all BH images.
Hi angelofsky1980.
Thanks for your answer. But i have a wireless adapter with rtl8812au chipset, and it does not work in my vu+ zero 4k. In another forum someone told me that the problem has to be with the vu+ zero 4k kernel. Can you please help?
Best regards
Hi angelofsky1980.
Best regards
Probably your device is not listed into driver sources.
Post here model, brand and hardware revision of your wireless device please and we'll investigate.
Hi angelofsky1980.
I bought the wireless adapter in aliexpress. Here is the device:
https://www.aliexpress.com/item/USB3-0-AC-1200Mbps-Wireless-Dual-Band-USB-Adapter-Wireless-Network-WiFi-Adapter-2-4-5/32842909137.html?spm=a2g0s.9042311.0.0.4bf64c4dleBuQK
I can´t find the data you asked me to, but i did find this info in the device:
Realtek 8812AU wireless lan 802.11ac usb nic
Controller version: 1030.23.502.2017
I hope this info is usefull.
Best regards
Hi angelofsky1980.
Best regards
Unfortuantely these info are not useful to identify the USB IDs used by your device.
Hi angelofsky1980.
How can i get more info? The wireless device doesn´t work in vu+ zero4k, but it works in windows pc.
Is there any way to find the info that you need?
I´m newbie, so i don´t know what to do more.
Thank you for all your help.
