Realtek rtl8812au driver for new Vu+ kernel
Unfortuantely these info are not useful to identify the USB IDs used by your device.
Hi angelofsky1980.
How can i get more info? The wireless device doesn´t work in vu+ zero4k, but it works in windows pc.
I have found this info in my windows pc:
Realtek 8812AU Wireless LAN 802.11ac USB NIC
Ethernet 802.3
PNP Device ID: USB\VID_0BDA&PID_8812\123456
Service name: RtlWlanu
Is there any way to find other info that you need?
I´m newbie, so i don´t know what to do more.
Thank you for all your help.
Hi angelofsky1980.
Ethernet 802.3
These infos are sufficient, thanks.
I've checked USB VID and USB PID in to WikiDevi website (https://wikidevi.com/wiki/Realtek_RTL8812BU_USB_Module) and seems your device uses RTL8812BU chipset and there is no driver at the moment who support it on Linux.
We can try to add the USB IDs into actual 8812AU driver but there is a very high possibility that didn't work.
angelo, i tried install one ipk from other vu+ image i received this error in attach.
Hi angelofsky1980.
Do you expect that rtl8812BU linux driver could be available soon?
And how can i try the 8812AU driver with this USB IDs?
Thanks again for all your help
Hi angelofsky1980.
Hi angelofsky1980.
I'm working ATM on Ralink devices and Vu+ boxes to have a more stable driver.
During winter holidays I'll work also on RTL8812AU driver ....
Hi angelofsky1980.
Ethernet 802.3
According with your box kernel and sorce code driver, your device should be already present so the device should be recognized by software and can be already configured.
As you wrote, the device is not yet discovered so some debug output should be needed to investigate and solve the problem.
Hi angelofsky1980.
Seems someone has found a rtl8812bu linux driver and I'm working on it.
I need Amazon links for some devices who uses that driver to make local tests.
That´s good news angelofsky1980!
Please tell me when you finish rtl8812bu driver for my vu+ zero4k.
If i can help you anyway please tell me.
Have a nice new year!
I should receive in a couple of days some USB dongles ordered on Amazon .... one should use the driver you need....
Hi I have the Realtek RTL8811AU Wireless LAN 802.11ac with the cd and it does not work on my VU+ Solo BH, IF you like me to post it to you to have a look please PM many thanks for the great job you do
I need USB PID and VID to identify your wifi device into driver source code.
Hi angelofsky1980,
I'm using newest BH 3.08 on Uno 4k SE and my Archer T4U with rtl8812bu (https://wikidevi.com/wiki/TP-LINK_Archer_T4U_v3) doesn't work… I've found a driver on GitHub (https://github.com/BlackHole/rtl8822bu), but as a total newbie, don't know if it is possible to install it and how to do it.
Best regards
Hi angelofsky1980,
Best regards
The GitHub repository you've found has been forked by me.
The driver is in testing phase and avaiable soon.
Thanks for USB IDs.
  • Like
Reactions: Szh
Hi and thank you very much
I found this on the USB
Realtek RTL8811AU Wireless LAN 802.11ac USB 2.0 Network Adapter
USB\VID_0BDA&PID_A811&REV_0200
USB\VID_0BDA&PID_A811\00E04C000001
usb\vid_0bda&pid_a811
Help. I have this wifi adapter (Plexgear AC600 nano) with a linux driver "rtl8821AU_linux_v4.3.14_13455.20150212_BTCOEX20150128-51.tar.gz". Have to make this run in Zero with Blackhole 3.0.8.A
