Transmission
Ok check the name of the file and the path.
Remember: into Unix/Linux OSes the files are case sensitive.
I haven't isntalled Transmission in my box ... I cannot test it :(
i recheck name
root@bm750:~# dos2unix / usr/scripts/Start_Transmission_userscript.sh
dos2unix: can't move '/txybQ2' to '/': Device or resource busy
i recheck name
Try with:
dos2unix /usr/scripts/Start_Transmission_userscript.sh
The space between first "/" and the rest of path it's a problem ;)
What i can do, after start any torrent, in couple of minutes network in box freeze and only restart help, exist some how to set some settings right?
Waouw! beautiful plugin! i'm downloading at this time a torrent directly to the VU+DUO
at the end, i will check if seeding works fine...
thanks to the conceptors!:thankyou:
ok , thanks.
but what port is used by tranmission plugin ?
remarque:
*i put the file transmission in etc/init.d with attribut 755 like said in the post then i had to change the path in start and stop script to:
/etc/init.d/transmission start
*i had also to change the downloading path in transmission script from media/hdd/torrent to media/hdd/movie just to be find easily by video plugins.
like you said tamaki, the seed works fine ! what a great plugin!
i recommand it to all of you people !
i have now my own seedbox on vu+duo ( with a limit speed of my connexion of course...) but it's great to be free to shutdown the PC !
thank you guys !:victory:
Happy to know all is right ;)
