Transmission
Absolutely cannot, i download succesfully to now 10 torrents without any problems, look in transmission log, which says.
The error is due to the fact that I use Transmission Remote GUI program to add torrents. When I use it with 2.52, transmission crashes. Back to 2.41 ;)
Hi everybody, I am facing a strange issue with this plugin.
When I accessed the Web interface the first time it worked well, but now I got this error:
404: Not Found
/hdd/transmission/web//index.html (No such file or directory)
Please advise :-)
Hello,
What is the username and password for accessing webif of Transmission?
I tried root and pass, but it's not working
Can't acess it? Can somebody help me please?
Thanks,
Ok I installed the configuration file, but browser still won't accept the access...
I am on Firefox for Mac... But its not working with root, pass
Thanks in advance,
Hi!
I Have VU + Duo BH 1.7.8 Light HDD USB mounted (Segate 500)
in Web Mozilla written:
403: Forbidden
Unauthorized IP Address.
Either disable the IP address whitelist or add your address to it.
If you're editing settings.json, see the 'rpc-whitelist' and 'rpc-whitelist-enabled' entries.
If you're still using ACLs, use a whitelist instead. See the transmission-daemon manpage for details.
etc/Default/transmission daemon
# Default values for transmission daemon
# please fill in and enable service.
DAEMON_ENABLED="yes"
DAEMON_USER="transmission"
DAEMON_GROUP="transmission"
DOWNLOAD_DIR="/media/hdd/torrents/"
CONFIG_DIR="/media/hdd/transmission"
Help me please! what need i do? sorry I'm new
if you can write more
Thank you!
Hi!
403: Forbidden
Thank you!
Put these config files:
http://www.vuplus-community.net/board/threads/transmission.3647/#post-30765
user: root
password: pass
You should solve.
hello again:)!
i reinstall BlackHole 1.7.8 lite
and again reinstall your all files and install transmission_config_bh.tgz (/tmp/install transmission_config_bh.tgz and in BH Addons Manager -Manual Install BH packget ---install---OK)
,,,the packges install successfully,,,
When I install I have not noticed any bugs
but mozilla displays exact same error.
can be a problem in rights? or am I doing wrong installationtransmission_config_bh.tgz ?:wallbash::)
thanks all, but i dont know how i do it
0.restart full sistem
1.reinstall all packges
2.change transmission daemon etc/Default/transmission daemon---755
3.change right files: /usr/skript/ start transmission------755
/usr/skript/ spop transmission-------755
/usr/skript/ transmission-------------755
restart
Green button----blue button---------start transmission--------see-OK
but after the restart to be run again > Green button----blue button---------start transmission
Thank you Tamaki
