USB Tuner: SMSUSB devices
hello friends
I made ​​a couple of photos
and upload this
it missing only the signal indicator
Merry Christmas / Merry Christmas / Καλά Χριστούγεννα
It's normal you don't see SNR (with VTI image).
You should try to use BH 1.6.7 image and latest IPKs published above in this post for Uno.
Hello angelofsky1980.
Is it possible to install USB Tuner Crypto ReDi PC 200 on 1.7.1?
Are there any drivers available for this stick?
Thanks in advance.
Thanks in advance.
Uhm ...... at this time we are working hard on the DVB part of the image ..... I can check your request only within 2 or 3 days....
Thanks in advance.
Your device is not a SIANO but has internally a REALTEK RTL2382 chipset.
We are planning to support it in the near future.
Dear Angelofsky,
I was planning to purchase Crypto ReDi PC 100 which is already supported by black-hole images.
Unfortunately I did not find this usb stick at the market and i purchased Crypto ReDi PC 200.
Thanks a lot for your time and i hope that soon it will be available drivers for REALTEK RTL2382 chipset
I found into 100618_RTL2832_36_40_10b_Drivers folder the ministick.txt file.
Could you please advise me how to install it at black hole 1.7.1 image?
