USB Tuner: SMSUSB devices
Dear angelofsky1980 Hello.
I have same Stick Crypto ReDi PC100.
Also not working with new Image 1.6.7 for VU+ Solo.
I have updated CFE, Install new image with clean new setting.
My DVB-T tuner not working.
Here is my 3 .txt files (dmesg / ls /cat).
Regards.
jep exactly like me at my friend
we must wait for an update
Merry Christmas Frohe Weihnachten Καλά Χριστούγεννα
Who have problems with SMSUSB device (Greek devices for example) install this BH package and reboot your box.
I have Reinstall image 1.6.7
Boot image / install patch / reboot image / insert usb DVB-T Tuner / reboot image.
But nothing, still the DVB-T Tuner is not working.
Here new .txt logs.
Thank you for concern dear angelofsjy1980.
Here new .txt logs.
Have you installed the BH package attached to my previous post?
hello friends
I made it
with a tip of vti forum
have experimented with the 4.0 vti
following the first time I set the driver
1.in the lib / firmware
2.telnet comand: modprobe smsdvb
restart GUI and it will light
Man must be restarted after each
always telnet comand: modprobe smsdvb + restart GUI
3.oder the modprobe smsdvb writing in / etc / init.d / bootup
restart box and it will light
and you do not need a telnet comand
I have not only the signal indicator
Merry Christmas / Frohe Weihnachten / Καλά Χριστούγεννα
hello friends
I made it
Your attachment is already included into BH image 1.6.7 for Solo (Duo and Uno needs firmware IPK I've posted in this thread).
At this point, I ask you a dmesg output when you restart the box.
It's no-sense operation: smsdvb.ko object is been loaded dinamically by kernel with other sms-drivers (there are 3 kernel objects for SMSUSB driver) but without "dmesg" I cannot clarify in my mind the soluzion.
Perhaps the mistake was only
the telnet command: modprobe smsdvb
we had not performed until now.
is just a thought from me.
Merry Christmas / Merry Christmas / Καλά Χριστούγεννα
Usually the "modprobe smsdvb" will be executed internally by kernel.
It's possible (I think it's sure) the new kernel has some checks and doesen't execute that command but the old kernel 2.6.18 execute ever.
I have applied some patches to kernel 3.1.1 inspired by link you have posted. I will publish here the IPKs to install in our Vu+ boxes.
hello friends
I made ​​a couple of photos
and upload this
it missing only the signal indicator
