USB Tuner: SMSUSB devices
Hello
have my Vu + uno
with the new B H v1.6.6
I also have DVB-T tuner Crypto Redi PC 100
and I have (Sorry no supported device found)
have the new driver usbtuner v0.3.5
Collapsed many times many times not
and whom it sometimes works then I can only go standby.
Who should I go to the box with power off, then everything is gone.
what am I doing wrong is where the fault.
Greetings from Greece
Hello
have my Vu + uno
Post a "dmesg" command output when the USB device is not detected.
Hello
have now made ​​two dmesg
First dmesg1 standby usb turner ok.
and from last night.
Second dmesg2 DeepStandby is noon today.
tuner was ok, I then made ​​on deep standby and on again, make
and promt came the message (sorry, no supprted device found. ).
Hello
Now there is one week ago, and wanted to ask me whether what has since developed.
I have (after the DeepStandby)
DVB-T stick pull out
start box
drivers instalation
box restart
DVB-T stick plug it
Blue button> usb tuner panel> enabel
gui restart
This is of course the stupid thing
every day the same procedure.
Regards from Greece
hello friends
I updated to the new version 1.6.7 Back Hole
But my usb-t turner (Crypto Redi pc 100) is not enabel?
(Crypto Redi pc 100) = Hauppauge WinTV MiniStick
why? or am I doing something wrong.
please help
gives the driver as ipk ?
so that I can manually install
Greetings from Greece & Merry Christmas
hello friends
please help
Install this IPK, reboot your box ... and your device should start to work.
Install the IPK with this telnet command:
ipkg install --force-overwrite file.ipk
file.ipk must be the filename you want to install into your box.
thank you angelo
'll try it today afternoon
So: ipkg install - force-overwrite file.ipk = ipkg install firmware-bh_1.0-r1_all.ipk
1.firmware-bh_1.0-r1_all.ipk in tmp folder
2.telnet command: ipkg install firmware-bh_1.0-r1_all.ipk
is that correct ?
thank you angelo
is that correct ?
ipkg install --force-overwrite firmware-bh_1.0-r1_all.ipk
Hello
I just made ​​it
But it does not work
the stick is not enabel.
says the telnet
[H [Jroot vuuno @: ~ #
ipkg install - force-overwrite-firmware-bh_1.0 r1_all.ipk
opkg:
firmware-bh_1.0-r1_all.ipk: No such file or directory
Collected errors:
* Failed to extract file from control-firmware-bh_1.0 r1_all.ipk
vuuno root @: ~ #
opkg: firmware-bh_1.0-r1_all.ipk: No such file or directory
Collected errors:
vuuno root @: ~ #
have telnet File Upload
Hello
I just made ​​it
says the telnet
opkg:
Collected errors:
vuuno root @: ~ #
Collected errors:
vuuno root @: ~ #
Upload the ipk in /tmp folder of your box and (via telnet) send this command:
ipkg install - force-overwrite /tmp/firmware-bh_1.0 r1_all.ipk
and here is the telnet protocol
Vuplus 2.2.0 + BlackHole 1.6.7 vuuno
vuuno login:
root
root@vuuno:~#
-------------------- < Script > ----------------------------
uname -r >/tmp/boxtype.dcc; echo ">>> DONE <<<";
>>> DONE <<<
root@vuuno:~#
clear
root@vuuno:~#
opkg:
Collected errors:
* Failed to extract control file from r1_all.ipk
root@vuuno:~#
df -m > /tmp/meminfo.dcc; echo ">>> DONE <<<";
>>> DONE <<<
root@vuuno:~#
vuuno login:
root
root@vuuno:~#
>>> DONE <<<
root@vuuno:~#
clear
root@vuuno:~#
opkg:
Collected errors:
root@vuuno:~#
>>> DONE <<<
root@vuuno:~#
Sorry!
I've copied the filename from your previous post and I've not seen an error on filename!
The correct command is:
ipkg install - force-overwrite /tmp/firmware-bh_1.0-r1_all.ipk
telnet protocol
vuuno login:
root
root@vuuno:~#
>>> DONE <<<
root@vuuno:~#
clear
root@vuuno:~#
Upgrading firmware-bh on root from 1.0-r0 to 1.0-r1...
Collected errors:
* Cannot find package -.
* Cannot find package force-overwrite.
* Package firmware-bh wants to install file /lib/firmware/dvb_nova_12mhz_b0.inp
But that file is already provided by package * firmware-dvb-usb
* Package firmware-bh wants to install file /lib/firmware/isdbt_nova_12mhz_b0.inp
* Package firmware-bh wants to install file /lib/firmware/rt73.bin
* Cannot find package firmware-bh.
root@vuuno:~#
>>> DONE <<<
root@vuuno:~#
telnet protocol
vuuno login:
root
root@vuuno:~#
>>> DONE <<<
root@vuuno:~#
clear
root@vuuno:~#
Collected errors:
root@vuuno:~#
>>> DONE <<<
root@vuuno:~#
It's a very bad day for my attention. Please excuse me. My workday make me very tired :(
ipkg install --force-overwrite /tmp/firmware-bh_1.0-r1_all.ipk
no problem angelo
next telnet protocol
vuuno login:
root
root@vuuno:~#
>>> DONE <<<
root@vuuno:~#
clear
root@vuuno:~#
Installing firmware-bh (1.0-r1) to root...
Configuring firmware-bh
root@vuuno:~#
restart box and stick not enabel
no problem angelo
vuuno login:
root
root@vuuno:~#
>>> DONE <<<
root@vuuno:~#
clear
root@vuuno:~#
root@vuuno:~#
Ok reboot your box again and post here the output of these commands please:
dmesg
ls -l /lib/firmware
cat /proc/bus/usb/devices
There are three separate commands. Pay attention to spaces ;)
I now unpacked the ipk
and everything was in it is copied with ftp
restart box
brought nothing but
the usb is not enabel
