USB Tuner: SMSUSB devices
Dear Angelo.
I have tested my stick at 2 different Windows PCs.
No problem found. Stick is recognized correctly and drivers install OK.
Channels scan fine and plays OK.
ON my VU+ Solo Receiver stick is not recognized. :lamo:
- Remove All USB devices.
- Flashed 1.6.6
- Booted
- Installed LAN and DVB-T Stick
- Rebooted
- install Driver
- Enable tuner
- Error message .. Sorry no supported device found ....
- Hard Restart
- Enable tuner
-Power off reciver (Remove 220V/AC cable)
- Enable tuner
- Extract Dmesg-1.6.6.txt
- Flashed 1.6.5
- Booted
- Rebooted
- install Driver
- Enable tuner
. e
. t
. c
-Extract Dmesg-1.6.5.txt
Before installing new image Stick was working Perfectly. :confused:
Regards.
Package SMSUSB on server UPDATED for all Vu+ boxes.
After I read your last message I try to reflash, downolad the driver and enable it for wintv hauppage ministick and the same error appears:
Sorry, not supported device
P.d: BH 1.6.6 and Vu+uno
Please post the "dmesg" output when appear "no supported device found".
Dear Angelo.
I have flashed VU+ Solo with 1.6.5 Firmware.(For Hdmi-cec compatibility)
Restored USB Tuner Driver from my Personal Backup and all works fine !
Once i have time i will start my trials soon.
Thank You.
P.S
Personal Backup is one of the best features ever made. Highly Recommended :thumbup:
Dear Angelo.
Thank You.
P.S
Test the native driver within 1.6.6 when you have possibility.
Tnx!
Angelo, i forget one thing.....
In UNO at least, /lib/modules/dvbt/bh-api.ko DON'T INSTALL IT!! Gives a error!! Too with Green HD!!
Any ideas?
Thanks again!!
Any ideas?
Thanks again!!
The file you mention is a very old object and is not yet needed.
I'm @ home now and I will upload NOW the correct package.
Sorry for my big mistake.
Thanks a lot and thanks again for your patiente with us......We're very busy, my friend!! ;)
Regards from Spain
Regards from Spain
I've made some tests during play a BD film (on my new BD player :) ) on Solo and Ministick and the device is still detected and usable. Some crossed tests are made (USB stick + DVB, Wifi Stick + DVB). I haven't tested with an Hub USB and the usage of more 2 USB devices but this kind of test will be done tomorrow evening or friday evening as the last date.
Is hauppage wintv ministick working now on Vu+uno?
On Uno we are making more intensive tests to discover the cause of non-working.
We have verified on Solo the proper working of Ministick device (updated package already on the server and tested by me and other colleague Admin who have the same device).
Thanks Angelo.....
In Uno, as you know says: Driver version: 0.3.5 SMUSB: c9aa0dc730b96675931e9d1793aa4e79e6b6b1b4
Sorry device not support... :mad:
We wait for your tests...
Thanks once more time for your time and work.
Regards from Spain...
Thanks Angelo.....
My Uno actually wait the Universal Remote Control (my prototype arrives with Duo/Solo remote .... and I cannot make direct tests with new 1.6.6 Image). My colleague Admin who make tests reports very strange errors and results :( I need to make direct test with a clean install image :( actually there is a very caotic image on my Uno .......
:D:D still without remote? oh my god :grin:...
Do you want I install clean 1.6.6 and be your tester? As you want without problems.....
Good luck with your remote...and be patiente.....
Thanks Angelo
Regards from Spain
Thanks Angelo
Regards from Spain
My Uno Remote is already arrived in my country. My friend has received it for me and I wait to receive it with some USB sticks :) I'm a very patient man :D
Hello Angelo... Have you received already your Vu+uno and hauppage wintv ministick and have you maked the tests and have you found the solution already?
Regards.
Regards.
I have a Uno prototype with old remote control and I've bought a Ministick two weeks ago. The DVB device works correctly with Duo and Solo. On Uno I haven't make intensive tests with last BH image because it's need the Universal remote control (or New remote control) to properly use the image.
My new remote control unit is parked to my friend shop who send me it with a lots of Wifi sticks to be tested on the boxes :)
Dear Angelo.
Today i have tested driver with BH image 1.6.6.
Everything finally is OK. :thumbup:
MY Connection: VU+ Solo rear USB>4portHUB /Stick/HDD/DVB-T
P.S
HDMI-cec
I have change option Wakeup signal from TV to Source Request and now the receiver turns ON/OFF when I Turn ON/OFF the TV.
But still no annynet+ connection with receiver when i scan for compatible devices from TVs menu.
Dear Angelo.
P.S
HDMI-cec
I'm very glad to read your success :)
