USB Tuner: SMSUSB devices
Hello, thank you very much in advance I have a usb nano hdtv real npg brand with the chip and board sms2270 RD1140m places, know any driver. Could it work in my vu + image only with BH.
Thank you very much and sorry for my bad English.
I have re-flashed Solo to 1.6.5 installed smsusb driver from server.
I have removed USB-HUB install DVB-T stick directly to receiver,
reinstall driver Green button..... Sorry no supported device found....
Rebooted/re-flashed/rebooted/............ The DVB-T stick
not recognized with latest driver.
Regards.
Regards.
I need the output of "dmesg" after the message "No supported device found" and BH 1.6.6.
Hello.
Any News?
Please disable DVB-T tuner into USB Tuner panel (if results enabled of course) and re-select "Hauppauge Ministick" driver from drivers list.
I've tested my Solo with Ministick (SMSUSB driver) and it's correctly detected. For security only I've re-uploaded SMSUSB driver for all Vu+ boxes on server.
This is a screenshot of my Solo:
VuUNo...Bh 1.6.6, FPGA updated, etc....
...Sorry no supported device found......
Any ideas?
Thanks Angelo!
Any ideas?
Thanks Angelo!
On Uno we are already working to try to solve the problem.
On my Solo and Duo the Ministick works regularly but on our friend sakisdvb has detected the same problem of your Uno on his Solo :(
Could you please make this little test?
Flash a new 1.6.6 image
Configure LAN, install DVB-T Ministick Driver and afr this make all other config you want.....
Ofcourse dear Angelo.
But not tonight, my kids were very active. I am exhausted.
Besides i am having suspensions about the DVB-T stick condition.
I will test further the next days.
Thank you very much.
P.S.
My TV Samsung LE40M86BD does not connect with Receiver after Updated to 1.6.6
Receiver turns off if i set TV to Stby. If i turn on TV the Receiver stays Off.
P.S.
Thanks for your patience for DVB-T.
I will test tomorrow the HDMI-CEC part of Solo.
Dear Angelo.
I have tested my stick at 2 different Windows PCs.
No problem found. Stick is recognized correctly and drivers install OK.
Channels scan fine and plays OK.
ON my VU+ Solo Receiver stick is not recognized. :lamo:
- Remove All USB devices.
- Flashed 1.6.6
- Booted
- Installed LAN and DVB-T Stick
- Rebooted
- install Driver
- Enable tuner
- Error message .. Sorry no supported device found ....
- Hard Restart
- Enable tuner
-Power off reciver (Remove 220V/AC cable)
- Enable tuner
- Extract Dmesg-1.6.6.txt
- Flashed 1.6.5
- Booted
- Rebooted
- install Driver
- Enable tuner
. e
. t
. c
-Extract Dmesg-1.6.5.txt
Before installing new image Stick was working Perfectly. :confused:
Regards.
Dear Angelo.
- Flashed 1.6.6
- Booted
- Rebooted
- install Driver
- Enable tuner
- Hard Restart
- Enable tuner
- Enable tuner
- Flashed 1.6.5
- Booted
- Rebooted
- install Driver
- Enable tuner
. e
. t
. c
Regards.
Interesting errors.....
For your problem I will publish new driver package within 1 hour.
