USB Tuner: SMSUSB devices
I now unpacked the ipk
and everything was in it is copied with ftp
restart box
brought nothing but
the usb is not enabel
Greetings from Greece & Merry Christmas
I need output of the three command exposed in my previous posts to determine the problem.
Ok reboot my box again and post here the output of these commands
and upload the telnet protocol
Ok.
I don't know what you are doing, but you have mixed kernel drivers.
Put these 3 IPKs into /tmp folder of your box and issue this command:
ipkg install /tmp/kernel*.ipk
Reboot your box.
If this not solve your problem, reflash the Beta and install the firmware-bh IPK file, then reboot your box.
1.have the box new reflash
2.then the firmware-bh IPK file
3.usb stick plugged in and is not recognized
dmseg and others made ​​new
and uploads here
Ok we are near success.
Now your device is correctly detected BUT it's connected to a low speed USB.
Please connect directly to box or use an externally powered HUB USB.
Vuplus 2.2.0 + BlackHole 1.6.7 vuuno
vuuno login:
root
root@vuuno:~#
-------------------- < Script > ----------------------------
uname -r >/tmp/boxtype.dcc; echo ">>> DONE <<<";
>>> DONE <<<
root@vuuno:~#
clear
root@vuuno:~#
ps aux | grep usb
822 root 2636 S grep usb
root@vuuno:~#
yes only sat tuner in 1.6.6 2 tuners sat and terestial
vuuno login:
root
root@vuuno:~#
>>> DONE <<<
root@vuuno:~#
clear
root@vuuno:~#
ps aux | grep usb
root@vuuno:~#
Ok.
In /tmp folder you should find an usbtuner.log file.
Post it here.
vuuno login:
root
root@vuuno:~#
>>> DONE <<<
root@vuuno:~#
clear
root@vuuno:~#
ls -l /dev/dvb
drwxr-xr-x 2 root root 520 Dec 14 23:47 adapter0
root@vuuno:~#
Very very strange!
Have you changed USB port where is connected the device?
Try the last command issued to box with another USB port ....
Post here only there are differences.
If the device is correctly reigstered into system you should see adapter0 AND adapter1
I've just shot the usb
As with the black hole 1.6.6
and yes it was
Although each time the driver install
box and restart
But it worked but
I have no more and no less to it
new removed all usb
and only t usb stick directly on the box
and new ls -l /dev/dvb
vuuno login:
root
root@vuuno:~#
>>> DONE <<<
root@vuuno:~#
clear
root@vuuno:~#
ls -l /dev/dvb
drwxr-xr-x 2 root root 520 Dec 14 23:57 adapter0
root@vuuno:~#
and new tuner log
