USB Tuners AF9015 based supported!
I will make some other tests around AF9015 driver with devices at my home (I have 2 devices)
Thank you. I firmly believe that you are able to help me. As you do your tests with two devices at home is the note to switch channels with AF9015 also if it will take a recording from the head of the DVB-S2 tuner VU + AWD. Thank you for any help and I believe that you are able to fix this problem that I have with my DVB-T USB AF9015.
I wanted to ask if you already checked angelofsky1980 two tuners, which has AF9015? And when I can count on drivers to fix AF9015 that when switching from DVB-T USB AF9015 was not a black screen and restart the tuner trzebabyło VU + AWD. It is quite embarrassing when poenieważ record two different channels such as the DVB-S2, I can see from the DVB-T USB AF9015, but there is a black screen like it's nothing I can not watch - and then I do not restart the tuner VU + DUO since the last recording from dvb-s. Please help and understanding.
I have the same problems with my sinovideo which is also AF9015 BUT seems this problem is generic and i dont know if its the drivers problem or the Stick problem. Problem exists in Vu+Duo and also in all dreamboxes where i tested the stick.
The stick stucks when you watching H264 channels and the solution to make it work again is either you change channel to a Mpeg-2 channel or you need a reboot.
My opinion is to w8 a bit for guys to see what is going on with this stick and hopefully they will find a solution and i thank them for the great work they do so far.
Exactly how to write Bluechris is when I watch the channel in H264, and switch the channel MPEG-2 is then I have a black screen. Everything is fine when I watch channels such as H264 and H264 channels only toggle. So it is fine when I watch the channels in MPEG-2 and toggle channels in MPEG-2. Black screen appears when it changes the channel from H264 to MPEG-2 or MPEG-2 to H.264. Please Angelofsky1980 here is to just fix the drivers for the AF9015, that it was no longer a black screen when switching channels with the H264 to MPEG-2.
P.S. Angelofsky1980 Thank you very much for the excellent work he does for us.
I will make some tests round AF9015 driver with my only supported device (Aver Volr Black A850).
The other AF9015 possible device I have is not yet supported.
How was tested AF9015 tuner? Will there be a hotfix drivers for AF9015, so it was no longer when switching channels with MPEG-4 to MPEG-2 black screen?
My device work properly but is too bad with Duo box (is too fast for this kind of driver - I suppose).
The AF9015 device seems work bettere with Solo box.
More tests will be done in the next days.
And we can count on is that the tuner AF9015 will work just as well at VU + DUO as VU + SOLO? Will fix this, so at VU + DUO AF9015 tuner to work properly as VU + SOLO?
My AF9015 device (Aver Volar Black HD A850) works on both boxes but on Solo works better than Duo.
The main problem is the any driver for Tuner IC on the device that can contain some bugs.
And You try to convert the driver to AF9015 in order to work properly on vu + duo?
I cannot convert anything.
The source code for the two boxes is the same.
You can disconnect your device, replug it and do via telnet the following command:
dmesg | grep dvb
to discover what tuner chip your device has inside.
dmesg | grep dvb
After sending commands via telnet I got this:
OpenEmbedded Linux bm750
Vuplus 2.0.5 + BlackHole 1.5 bm750
bm750 login: root
root@bm750:~# dmesg | grep dvb
dvb_bcm7335: module license 'Proprietary' taints kernel.
dvb-usb: found a 'Afatech AF9015 DVB-T USB2.0 stick' in warm state.
dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
dvb-usb: Afatech AF9015 DVB-T USB2.0 stick successfully initialized and connected.
usbcore: registered new driver dvb_usb_af9015
dvb_demux_feed_del: feed not in list (type=0 state=0 pid=ffff)
root@bm750:~#
Can you post the entire dmesg output please? Attach a file with the output please.
Thanks a lot.
This entry from my telnet after restarting the tuner
bm750 login: root
dvb-usb: found a 'Afatech AF9015 DVB-T USB2.0 stick' in cold state, will try to load a firmware
dvb-usb: downloading firmware from file 'dvb-usb-af9015.fw'
I do not know where to find the file with the output, which is why I sent you two files and usbtuner0 usbtuner. I do not know whether on these files you wanted.
If not, please give me their locations, so I knew that I send you.
To obtain dmesg output do the following command:
 dmesg > /tmp/dmesg.txt
Next, you can get the dmesg.txt file from /tmp folder.
Thanks for the file.
From the output it's clear that you have an AF9015 device with a QT1010 tuner.
I haven't a device with this configuration but I will look the web for fixes around it.
Thank you, that will help me to give me the tuner to work properly AF9015 at VU + duo. I have the installation CD into the tuner AF9015 to run on your computer, but here the idea is to have the correct drivers to work on my VU + Duo. Please for your help.
Angelofsky1980 Thank you! How do you manage to get my fix to work properly AF9015 at VU + DUO then it'll be a new driver for my AF9015 you'll need to install the usb tuner panel if it will be the same driver in the revised version?
If I find the problem you will be noticed in this thread.
