USB Tuners AF9015 based supported!
Angelofsky1980 I wanted to ask if tonight you add the drivers for my device AF9015 device with a QT1010 tuner? We ask you to help my AF9015 QT1010 device with a tuner to work properly with the Black Hole 1.5 Multituner and I could install the correct drivers for my device AF9015 device with a QT1010 tuner.Please help.
I haven't done any kind of tests around the AF9015 driver in these days.
You should wait some days...
Halo, Angelofsky1980
Today, the test image Uploader Nemesis 2.2 and it turned out that I installed drivers for my device AF9015 device with a QT1010 tuner has no problems and it works perfectly. I care more on this to my device AF9015 device with a QT1010 tuner work just perfectly on Black Hole 1.5 multituner. Maybe it would be for you an indication as to improve the device drivers for my device AF9015 device with a QT1010 tuner in Black Hole 1.5 Multituner. Please help.
It turned out that the Nemesis 2.2 not working properly and get a black screen, especially when it comes to switching between channels of MPEG-2 and MPEG-4. So is the same problem as the Black Hole. Waiting for the correct drivers from Angelofsky1980 for my device AF9015 QT1010 device with a tuner.
Seems that even if my both devices have same chipset AF9015 (my devices are a A850 and a Sinovideo) the A850 behaves better than the sinovideo. The black screen problem appears less in the A850 and more frequent in the Sinovideo). Still also havent manage to make both devices work simultaneously in latest 1.5.1 BH, the A850 works fine but the Sinovideo (Tuner D) produces black screen always in dual DVB-T configuration.
More Crucial to me is to fix the bug of the Black Screen in the one tuner and then proceed to the dual tuner configuration .. also thx for the efforts you do guys for us :)
i have problem with my usb dvb-t tuner with af9015 after 1.5 version
with 1.4.6 work fine but with 1.5 and 1.5.1 dont find chanels
with telnet command box tell:
Vuplus 2.0.6 + BlackHole 1.5.1 bm750
bm750 login: root
root@bm750:~# dmesg | grep dvb
dvb_bcm7335: module license 'Proprietary' taints kernel.
dvb-usb: found a 'Afatech AF9015 DVB-T USB2.0 stick' in cold state, will try to load a firmware
dvb-usb: downloading firmware from file 'dvb-usb-af9015.fw'
dvb-usb: found a 'Afatech AF9015 DVB-T USB2.0 stick' in warm state.
dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
dvb-usb: Afatech AF9015 DVB-T USB2.0 stick successfully initialized and connected.
usbcore: registered new driver dvb_usb_af9015
root@bm750:~# dmesg > /tmp/dmesg.txt
root@bm750:~#
help me please
I've updated the package on the BH server for AF9015 devices (updated DVB API).
I've make some tests with Vu+Solo and my Aver Volar Black HD A850 and works correctly
Angelofsky1980,
Thank you very much for the great work on the drivers! Now my device AF9015 device with a QT1010 tuner works great! Thank you very much for the image Black Hole 1.5.1 and for the drivers for DVB-T tuner !
Angelofsky m8 really thx ... Both my tuners now work fine now in my dual DVB-T tuner configuration (A850 and a Sinovideo Af9015). Also seems so far after 5 mins extremme zapping that the black screen problem dissapeared.
I have no words... thx m8 really.
Hi,
I have the latest release of BH on Vu+ Duo - my question..
Will Aver Media Volar Black HD TV Stick work as my dvb-t or can someone recommend a model ...thank you
I got also some blackscreen issues with Kworld 395u stick.
Mostly with encrypted channels, after going to DVB-T FTA channel and then back to scrambled one i got the picture.
dvb-usb: found a 'KWorld USB DVB-T TV Stick II (VS-DVB-T 395U)' in cold state, will try to load a firmware
dvb-usb: found a 'KWorld USB DVB-T TV Stick II (VS-DVB-T 395U)' in warm state.
dvb-usb: schedule remote query interval to 500 msecs.
dvb-usb: KWorld USB DVB-T TV Stick II (VS-DVB-T 395U) successfully initialized and connected.
dvb_demux_feed_del: feed not in list (type=0 state=0 pid=ffff)
I just test to update drivers via USB tuner panel, but still got the issue.
BH 1.5.1
Hi,
Aver Volar Black HD A850 works with BH 1.5.1 images without problem but needs a very strong and stable DVB-T signal to get max performances.
BH 1.5.1
Ok.
Thanks for this report.
I will check if exists some patches to make better support for your device.
Is multiple recording supported on this driver (af9015)?
Last night, had 2 scheduled recordings, first one began, continued for 40 minutes, second started, both continued further 4.5 minutes, then recordings stopped, black screen, "No data on transponder".
This is with cheap AF9015 device. Would Avermedia Volar be better, or is it a driver limitation?
