Vu+ DUO Boot Loader Updgrade
Hi Terrorman,
I reviewed the logs, but I do not have an answer for you so far.
Do you think it is possible to have a log from very start of the boot to the end?
Can you guarrantee the Duo is original?
Thanks,
Raist
I have problems with a DUO
I updated the boot but not start the new images, the clock at the start of enigma waiting for hours
original image with a 4.7 works perfectly, with no BH 1.7.2
I attached the two log if you can help
thx my friends
Are you sure that this log is the log from BH image ??
If so, then something is wrong with this image or box
because it is not fully installed or is defective file
download image agn and install agn.
because files are missing in this image that is why he can not boot
yes my friend, is full log BH 1.7.2 and Original Image log....
I am going to try, using the program vu+ useful with cable rj45 and rs232
then I say something with the result.
thx my friend,
i tried some :rolleyes: .
if i use the official enigma2 image boots correctly
if i use the BH 1.7.2, enigma2 will not finish booting.
i upgraded boot twice, is updated correctly.
is very strange
I'm not that expert, but... are you using SCART on this box?
It seems it dies initializing max9597 single SCART interface.
If so, try to connect it through HDMI. Just to isolate the problem.
is very strange
When BH image do not finish booting , there must be process vault during USB instillation,,,,it may be not Unzipped correctly to USB or U need new, clean and formatted USB!
Any way!
Go for older BH Image , like 1.63...and lets see!
And I think Original image is now ver 7 not 4.7!
This is a strange problem, have you tried a different USB to flash with as suggested by MX ?
yes i've tried five different with the same result, the interesting thing is that if i put an old picture, BH 1.6.5 for example, works perfectly
Any way!
ok my friend, tomorrow i'll do further checks, i understand what you mean
Ok fine!
As seen from U'r post that BH 1.65 works perfectly.....then I think U'r problem that NO boot loader of cfe was upgraded, since the up grade started from BH 1.66!
U need to upgrade the boot loader cfe ver 3 and all should work OK!
http://archive.vuplus.com/image/2011/6.0/duo_cfe_3_0_usb.zip
http://archive.vuplus.com/image/2011/6.0/HOWTO_UPDATE_DUO_CFE
And make sure to unzip directly to USB!
RgdZ
a911
