I have a Vu+ Duo with a 500GB harddrive installed. I can not get it to accept the USB at all. There is some read/write activity from the stick then nothing.
Is it because it's a 32 gig stick? It's formatted as FAT32.
Can I just check the correct file positions? On my computer it shows as F:\vuplus\duo\[the two files are in this location]. Is that correct? No idea why it's not working :\
Hi
occasionally when i turn off my receiver or reboot it
my receiver panel show me starting while chanel is ok and appierace and run but remote control doesnet work
and i should turn off my receiver with behind receiver and then my recievr i be ok
write in panel:
staring and hanging
not often or absolutly time it happens at time or 7-8 times in week
my receiver vu duo 1
Hi
write in panel:
staring and hanging
That is a fact, am facing the same problem with my Due, there is a solution, put a long ago by Matrix 10, I did not do it!
But try to search the forum for it!
Sorry,,,,!
have same problem and sent to Duotech eletronics birmingham, please if you flashed nad still not working then contact duotech electronics n it will be sorted, sent my box for repairs and they have done a good and updated all components and all files.
Hey guys I've just been given a vu+ duo I've dealt with openbox and cable boxes before but never a duo. How do I go about deleting the line already on the box and adding my own
hi all
i have a vuduo that just hangs with starting in the display....
while readting all the thread find it intresting, i have a log file which i will try and upload for your help
this log is taken when i upgrade to cfe 3 and the reboot still hangs with starting in the display so any help would be great.
what in the log file is confermation that the new bootload is installed?
just for you info the usb work fine but when i install an image i only get starting in the display
ok will mick12334 not sure how to prove if its a clone or genuine, can you tell me how to prove this and if it is a clone does that mean this community will not be able to help me
thanks
joe
thanks
joe
