Vu+ duo completamente bloccato
Loader:elf Filesys:raw Dev:flash0.kernel File: Options:rootfstype=jffs2 root=/dev/mtdblock0 rw mem=0x8000000 bcmrac=3
Loading: 0x80001000/7078176 0x806c1120/122128 Entry address is 0x805594c0
TP1 Entry Address at 0x80000ffc = 805594c0
Starting program at 0x805594c0
Linux version 3.1.1 (amedeo@localhost.localdomain) (gcc version 4.4.3 (GCC) ) #1 SMP Sat Feb 4 21:29:53 CET 2012
Fetching vars from bootloader... found 11 vars.
Early serial console at MMIO32 0x10400b00 (options '115200n8')
bootconsole [uart0] enabled
Options: sata=1 enet=1 emac_1=1 no_mdio=0 docsis=0 pci=1 smp=1 moca=0 usb=1
Using 256 MB + 128 MB RAM (from CFE)
bootconsole [early0] enabled
CPU revision is: 0002a044 (Brcm4380)
FPU revision is: 00130001
Determined physical RAM map:
memory: 10000000 @ 00000000 (usable)
bmem: adding 112 MB RESERVED region at 144 MB (0x07000000@0x09000000)
Initrd not found or empty - disabling initrd
Zone PFN ranges:
Normal 0x00000000 -> 0x00010000
Movable zone start PFN for each node
early_node_map[1] active PFN ranges
0: 0x00000000 -> 0x00010000
PERCPU: Embedded 7 pages/cpu @81203000 s4384 r8192 d16096 u32768
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 65024
Kernel command line: bmem=112M ubi.mtd=0 root=ubi0:rootfs rootfstype=ubifs rw rootflags=sync
PID hash table entries: 1024 (order: 0, 4096 bytes)
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Primary instruction cache 32kB, VIPT, 2-way, linesize 64 bytes.
Primary data cache 64kB, 4-way, VIPT, cache aliases, linesize 64 bytes
Memory: 138096k/262144k available (5523k kernel code, 124048k reserved, 1145k data, 244k init, 0k highmem)
Hierarchical RCU implementation.
NR_IRQS:128
Detected MIPS clock frequency: 404 MHz (202.497 MHz counter)
Calibrating delay loop... 403.45 BogoMIPS (lpj=201728)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
SMP: Booting CPU1...
SMP: CPU1 is running
Brought up 2 CPUs
NET: Registered protocol family 16
PCI2.3->SDRAM window: 512 MB
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Advanced Linux Sound Architecture Driver Version 1.0.24.
PCI: found device 14e4:8602 on SATA bus, slot 0 (irq 42)
pci 0000:01:00.0: BAR 5: assigned [mem 0x10510000-0x10510fff]
pci 0000:01:00.0: BAR 5: set to [mem 0x10510000-0x10510fff] (PCI address [0x10510000-0x10510fff])
pci 0000:01:00.0: BAR 6: assigned [mem 0x10511000-0x105117ff pref]
Bluetooth: Core ver 2.16
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
cfg80211: Calling CRDA to update world regulatory domain
Switching to clocksource upg
NET: Registered protocol family 2
IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP reno registered
UDP hash table entries: 128 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 128 (order: 0, 4096 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
NTFS driver 2.1.30 [Flags: R/W].
JFFS2 version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
msgmni has been set to 269
io scheduler noop registered
io scheduler cfq registered (default)
Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
serial8250.0: ttyS0 at MMIO 0x10400b00 (irq = 22) is a 16550A
console [ttyS0] enabled, bootconsole disabled
serial8250.0: ttyS1 at MMIO 0x10400b40 (irq = 66) is a 16550A
serial8250.0: ttyS2 at MMIO 0x10400b80 (irq = 67) is a 16550A
loop: module loaded
brcm-pm: enabling sata clocks
PCI: Enabling device 0000:01:00.0 (0000 -> 0003)
scsi0 : sata_brcmstb
scsi1 : sata_brcmstb
ata1: SATA max UDMA7 mmio m4096@0x10510000 port 0x10510000 irq 42
ata2: SATA max UDMA7 mmio m4096@0x10510000 port 0x10510100 irq 42
Broadcom STB NAND controller (BrcmNand Controller)
bcmemac: Broadcom STB 10/100 EMAC driver v3.0
bcmemac: registered interface #0 at 0x10080000 as 'eth0' (00:1d:ec:01:aa:54)
bcmemac: not registering interface #1 at 0x10090000 (no PHY detected)
usbcore: registered new interface driver zd1201
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
brcm-pm: enabling usb clocks
ehci-brcm ehci-brcm.0: Broadcom STB EHCI
ehci-brcm ehci-brcm.0: new USB bus registered, assigned bus number 1
ehci-brcm ehci-brcm.0: irq 62, io mem 0x10480300
ehci-brcm ehci-brcm.0: USB 0.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ehci-brcm ehci-brcm.1: Broadcom STB EHCI
ehci-brcm ehci-brcm.1: new USB bus registered, assigned bus number 2
ehci-brcm ehci-brcm.1: irq 57, io mem 0x10480500
ehci-brcm ehci-brcm.1: USB 0.0 started, EHCI 1.00
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
ohci-brcm ohci-brcm.0: Broadcom STB OHCI
ohci-brcm ohci-brcm.0: new USB bus registered, assigned bus number 3
ohci-brcm ohci-brcm.0: irq 63, io mem 0x10480400
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 2 ports detected
ohci-brcm ohci-brcm.1: Broadcom STB OHCI
ohci-brcm ohci-brcm.1: new USB bus registered, assigned bus number 4
ohci-brcm ohci-brcm.1: irq 64, io mem 0x10480600
ata1: SATA link down (SStatus 4 SControl 300)
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 2 ports detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
Success! Registering the characther device success with 0
blackhole initialised
Bluetooth: Generic Bluetooth USB driver ver 0.6
usbcore: registered new interface driver btusb
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
ALSA device list:
No soundcards found.
TCP cubic registered
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
lib80211: common routines for IEEE802.11 drivers
EBI CS0: setting up NAND flash (primary)
mtd->oobsize=0, mtd->eccOobSize=0
NAND_CS_NAND_XOR=00000001
B4: NandSelect=40000101, nandConfig=55042200, chipSelect=0
brcmnand_read_id: CS0: dev_id=ecf10095
After: NandSelect=40000101, nandConfig=55042200
Block size=00020000, erase shift=17
NAND Config: Reg=55042200, chipSize=128 MB, blockSize=128K, erase_shift=11
busWidth=1, pageSize=2048B, page_shift=11, page_mask=000007ff
BrcmNAND mfg ec f1 Samsung K9F1G08U0A 128MB on CS0
Found NAND on CS0: ACC=d3000000, cfg=55042200, flashId=ecf10095, tim1=4232222d, tim2=00000d94
BrcmNAND version = 0x0201 128MB @00000000
Found NAND flash on Chip Select 0, chipSize=128MB, usable size=128MB, base=0
brcmnand_scan: B4 nand_select = 40000101
brcmnand_scan: After nand_select = 40000101
page_shift=11, bbt_erase_shift=17, chip_shift=27, phys_erase_shift=17
Brcm NAND controller version = 2.1 NAND flash size 128MB @18000000
ECC layout=brcmnand_oob_bch4_4k
brcmnand_scan: mtd->oobsize=64
brcmnand_scan: oobavail=50, eccsize=512, writesize=2048
brcmnand_scan, eccsize=512, writesize=2048, eccsteps=4, ecclevel=15, eccbytes=3
-->brcmnand_default_bbt
brcmnand_default_bbt: bbt_td = bbt_main_descr
Creating 7 MTD partitions on "brcmnand.0":
0x000000000000-0x000007600000 : "rootfs"
0x000007600000-0x000007a00000 : "kernel"
0x000007a00000-0x000007c00000 : "boot"
0x000007c00000-0x000007d00000 : "cfe"
0x000007d00000-0x000007d80000 : "mac"
0x000007d80000-0x000007e00000 : "env"
0x000007e00000-0x000007f00000 : "nvm"
UBI: attaching mtd0 to ubi0
UBI: physical eraseblock size: 131072 bytes (128 KiB)
UBI: logical eraseblock size: 126976 bytes
UBI: smallest flash I/O unit: 2048
UBI: VID header offset: 2048 (aligned 2048)
UBI: data offset: 4096
ata2: SATA link down (SStatus 4 SControl 300)
UBI: max. sequence number: 507
UBI: attached mtd0 to ubi0
UBI: MTD device name: "rootfs"
UBI: MTD device size: 118 MiB
UBI: number of good PEBs: 936
UBI: number of bad PEBs: 8
UBI: number of corrupted PEBs: 0
UBI: max. allowed volumes: 128
UBI: wear-leveling threshold: 4096
UBI: number of internal volumes: 1
UBI: number of user volumes: 1
UBI: available PEBs: 0
UBI: total number of reserved PEBs: 936
UBI: number of PEBs reserved for bad PEB handling: 9
UBI: max/mean erase counter: 3/0
UBI: image sequence number: 839517463
UBIFS: parse sync
UBI: background thread "ubi_bgt0d" started, PID 44
UBIFS: recovery needed
UBIFS: recovery completed
UBIFS: mounted UBI device 0, volume 0, name "rootfs"
UBIFS: file system size: 115802112 bytes (113088 KiB, 110 MiB, 912 LEBs)
UBIFS: journal size: 9023488 bytes (8812 KiB, 8 MiB, 72 LEBs)
UBIFS: media format: w4/r0 (latest is w4/r0)
UBIFS: default compressor: lzo
UBIFS: reserved for root: 0 bytes (0 KiB)
VFS: Mounted root (ubifs filesystem) on device 0:12.
Freeing unused kernel memory: 244k freed
mount: mounting sysfs on /sys failed: Device or resource busy
procmk_init
dvb_bcm7335: module license 'Proprietary' taints kernel.
Disabling lock debugging due to kernel taint
BlackHoleapi: popclose,
[SEC] update curFE tune
rent switch params
[SEC] startTuneTimeout 5000
[SEC] setFrontend 1
setting frontend 1
[SEC] sleep 500ms
(1)fe event: status 0, inversion on, m_tuning 1
(1)fe event: status 1f, inversion off, m_tuning 2
OURSTATE: ok
[eDVBCAService] channel 0x1c0deb0 running
[eDVBLocalTimerHandler] channel 0x1c0deb0 running
no version filtering
0014: 70 00 00 00 00 00
mask: fc 00 00 00 00 00
mode: 00 00 00 00 00 00
[eEPGCache] channel 0x1c0deb0 running
[EPGC] next update in 2 sec
stop release channel timer
0012: 4e 21 3f 00 00 00
mask: ff ff ff 00 00 00
ok ... now we start!!
0000: 00 00 00 00 00 00
mask: ff 00 00 00[AUD]: AUDIO_SET_BYPASS_MODE 1
00 00
mode: 0[AUD]: proc_get_ac3 0 audio_passthrough_spdif : 0
0 00 00 00 00 00
eventNewProgramInfo 0 0
have 1 video stream(s) (0200), and 1 audio stream(s) (028a), and the pcr pid is 0200, and the text pid is 0240
allocate demux
disable teletext subtitles
decoder state: play, vpid=512, apid=650
DMX_SET_PES_FILTER(0x200) - pcr - ok
DEMUX_START - pcr - ok
DMX_SET_PES_FILTER(0x28a) - audio - ok
DEMUX_START - audio - ok
AUDIO_SET_BYPASS(1) - ok[AUD]: AUDIO_PAUSE 1
AUDIO_PAUSE - [AUD]: AUDIO_PLAY 1 decoder start : 0
ok
AUDIO_PLAY - ok
Video Device: /d[VID]: VIDEO_SET_STREAMTYPE 0
ev/dvb/adapter0/[VID]: VIDEO_FREEZE 1 0
video0
demux de[VID]: VIDEO_PLAY 1 2 2
vice: /dev/dvb/adapter0/demux0
VIDEO_SET_STREAMTYPE 0 - ok
DMX_SET_PES_FILTER(0x200) - video - ok
DEMUX_START - video - ok
V[VID]: VIDEO_SLOWMOTION 0 1
IDEO_FREEZE - ok[VID]: VIDEO_FAST_FORWARD 0 1
VIDEO_PLAY - o[VID]: VIDEO_CONTINUE 1 1
k
DMX_SET_PES_F[AUD]: AUDIO_CONTINUE 1 1 audio pid_hndl : 0xc0b35fcc
ILTER(0x240) - t[AUD]: setting mute : 0
tx - ok
DEMUX_START - ttx - ok
VIDEO_SLOWMOTION(0) - ok
VIDEO_FAST_FORWARD(0) - ok
VIDEO_CONTINUE - ok
AUDIO_CONTINUE - ok
not pauseable.
[AutoRes] service changed
-+ 1/2 TID 4e
+ 1/1 TID 00
done!
PATready
use pmtpid 0450 for service_id 213f
0450: 02 21 3f 00 00 00
doing version filtering
0000: 00 00 00 01 00 00
mask: ff 00 00 3f 00 00
mode: 00 00 00 3e 00 00
[SEC] set dynamic current limiting
+ 1/1 TID 02
done!
have 1 video stream(s) (0200), and 2 audio stream(s) (028a, 02b6), and the pcr pid is 0200, and the text pid is 0240
[eDVBCAService] new service 1:0:1:213F:3070:13E:820000:0:0:0:
[eDVBCAService] add demux 0 to slot 0 service 1:0:1:213F:3070:13E:820000:0:0:0:
[eDVBCIInterfaces] gotPMT
demux 0 mask 01 prevhash 00000000
[eDVBCAService] send 64 bytes
9f 80 32 3c 03 21 3f 03 00 13 01 81 08 00 82 00 00 30 70 01 3e 82 02 01 00 84 02 04 50 02 02 00 00 00 04 02 8a 00 00 04 02 b6 00 00 06 02 40 00 00 0b 0f a1 00 00 05 0f ab 00 00 0b 07 e9 00 00
0450: 02 21 3f 03 00 00
mask: ff ff ff 3f 00 00
sdt update done!
VIDEO_GET_EVENT - ok
[AutoRes] got event evVideoSizeChanged
[AutoRes] got event evFramerateChanged
[AutoRes] got event evVideoProgressiveChanged
++ 2/2 TID 4e
done!
0012: 4e 21 3f 29 00 00
[AutoRes] determineContent
[EPGC] start caching events(1329177326)
[eDVBLocalTimerHandler] diff is 0
[eDVBLocalTimerHandler] diff < 120 .. use Transponder Time
[eDVBLocalTimerHandler] not changed
[EPGC] abort non avail viasat reading
[EPGC] abort non avail mhw reading
[EPGC] nownext finished(1329177333)
[EPGC] schedule finished(1329177339)
no ancillary data in audio stream... abort radiotext pes parser
[EPGC] schedule other finished(1329177356)
[EPGC] stop caching events(1329177356)
[EPGC] next update in 60 min
[EPGC] start cleanloop
[EPGC] stop cleanloop
[EPGC] 283949 bytes for cache used
It's now Tue Feb 14 00:56:37 2012
[timer.py] next activation: 1329177497 (in 99999 ms)
It's now Tue Feb 14 00:56:38 2012
[timer.py] next activation: 1329177498 (in 99998 ms)
Spero che questo sia più utile.
Giuro questo è l'ultimo.
video0
k
tx - ok
VIDEO_CONTINUE - ok
AUDIO_CONTINUE - ok
not pauseable.
-+ 1/2 TID 4e
+ 1/1 TID 00
done!
PATready
+ 1/1 TID 02
done!
sdt update done!
++ 2/2 TID 4e
done!
Zone PFN ranges:
NR_IRQS:128
Brought up 2 CPUs
TCP reno registered
console [ttyS0] enabled, [CrossEPG_Auto] poll
[EPGC] 283935 bytes for cache used
[EPGC] 283907 bytes for cache used
It's now Tue Feb 14 00:58:17 2012
[timer.py] next activation: 1329177597 (in 99998 ms)
It's now Tue Feb 14 00:58:18 2012
[timer.py] next activation: 1329177598 (in 99998 ms)
It's now Tue Feb 14 00:59:57 2012
[timer.py] next activation: 1329177697 (in 99998 ms)
It's now Tue Feb 14 00:59:58 2012
[timer.py] next activation: 1329177698 (in 99999 ms)
[EPGC] 282377 bytes for cache used
It's now Tue Feb 14 01:01:37 2012
[timer.py] next activation: 1329177797 (in 99998 ms)
It's now Tue Feb 14 01:01:38 2012
[timer.py] next activation: 1329177798 (in 99998 ms)
It's now Tue Feb 14 01:03:17 2012
[timer.py] next activation: 1329177897 (in 99999 ms)
It's now Tue Feb 14 01:03:18 2012
[timer.py] next activation: 1329177898 (in 99998 ms)
It's now Tue Feb 14 01:04:57 2012
[timer.py] next activation: 1329177997 (in 99998 ms)
It's now Tue Feb 14 01:04:58 2012
[timer.py] next activation: 1329177998 (in 99998 ms)
Riparte sempre con molta lentezza adesso che ho riattaccato tutto ci avra messo almeno un minuto a far partire la scritta starting. Ho disabilitato l'hdmi-cec così non mi si riaccende il tv di notte :).
Adesso vado a dormire con il duo funzionante.
Buona notte a tutti
Buona notte a tutti
Visti gli ultimi log, il box sembra partire correttamente anche se ha dovuto fare il recovery della flash (questo è molto probabilmente il motivo dell'avvio lento).
Se hai l'abitudine di spegnerlo dal tasto psoteriore, evita di usarlo cosi a bruciapelo e manda il box in shutdown regolare dal menu di arresto.
Stanotte l'ho lasciato in st-by e stamattina funzionava regolarmente. Da oggi in poi farò sempre lo shutdown per spegnerlo. Rimane comunque monitorato.
Ciao e grazie!
Il decoder non smette di darmi problemi, si riavvia da solo, si blocca e a volte si pianta sulla scritta starting. L'unica cosa positiva è che ora riparte sempre.
Purtroppo si pianta senza dare spiegazioni (crashlog) .Ieri pomeriggio ho provato ad usare solo la scart e sinoltre a sera è fuori andato. Ho poi riattaccato la hdmi insieme alla scart e sino a notte è andata, stamattina però l'ho ritrovato piantato su starting .Ho distaccato la hdmi dopo 30 minuti si è ripiantato.Proverò a metterla img originale .
qualche volta ho avuto anche io lo stesso problema col solo..si piantava e solo riflashandolo ripartiva...infatti avevo postato sotto esame di angelofsky80 l'output per capire un pò cosa succedesse...la chiave di lettera anche secondo me stà nello spegnimento; il fatto che il solo (purtroppo)non abbia come tutti gli altri modelli il tasto on/off sul retro, comporta il fatto che se non è spento bene (deepstandy), si riscontrino problemi al prossimo avvio...
ripeto, io per ben 3 volte ho dovuto riflashre l'immagine...
Scusate il post sgrammaticato ma ero con lo smartphone che ha il completamento automatico delle parole. Escono spesso frasi senza senso in quanto il correttore decide per conto suo .Devo levare questa modalità.
Ciao
Da oggi alle 14 sto effettuando una prova. Ho fatto un shoutdown regolare ho staccato la HDMI la USB DTT e ho collegato la scart. Nessun restart e nessun impallamento sino a questo momento.
Si scade a dicembre.L'unico problema è che devo rispedirlo in Spagna dove l'ho comprato. Per caso sapete se lo posso mandare in riparazione tramite l'importatore italiano, se esiste?
Ho scritto alla Satco Europe che dovrebbe essere il distributore europeo ma mi hanno confermato che devo inviarlo al venditore.
Per ora ho varie idee. La prima sarebbe flasharlo con una originale ma poi non posso mettere la USB DDT oppure fare lo shoutdown regolare e staccare l' HDD ma tenendo sia la pennetta che l'hdmi. Insomma ho l'impressione che il problema lo creino queste due connessioni. Non so se sono alimentate sulla stessa linea e forse potrebbe dipendere da una tensione insufficiente che si è creata.Magari non alimentando l'HDD la tensione potrebbe essere sufficiente.Questo non risolverebbe il problema ma almeno lo circoscrive.
