Vu+ Ultimo LCD Picon user_skin.xml
Thank you very much. I did it as you said, and now my Ultimo runs perfectly with the new LCD skin. Before, I loaded Skin User Xml BH2.x for Lcd Picons VuUltimo by Ev0 v00... But I don't understand the meaning of "font". My English is not perfect!
Hi.
Here is the VFD skin that I made this weekend.
This one is with a long channel name or Picon.
The Picons that "you" have must be adjusted to "175,40".
To do that, make a new background size 175,40 on Photoshop.
Open also the existing Picon , cut it and paste to the new background. Save as existing name of the picon.
I don't use Picons but I made two examples in the rar file.
P.S. Please
BACK-UP existing files before overwriting them.
Regards
hija31
  • Ultimo_VFD_Hija31.rar
Hi.
P.S. Please
Regards
hija31
Thank you very much , i like very much the large infobar without picon
HI if somoone know how to add clock when i play my movies because only show the progress and the name of my movies
Hi.
Here is new user_skin file with some fixes and added the progress bar on Mediaplayer.
P.S.
Please don't install the user_skin if you didn't install the files from my above post because
it wont work.
Always make a back-up of the files before you overwrite them.
Thanks for the reply.
I posted the files in new thread to not corrupt this one ( sorry EvO ), and because they are without an picon.
If the admins or mods think that a new thread is not necessary or want to make a central thread for VFD skins they can move my files
where ever they want.
Regards, Hija31
Good morning, I install BH 2.0.3 on my demo.
Could you explain if it is possible, and how I'm able to install EvO's LCD picon on my Ultimo? Thank you.
Solveg92
Solveg92
Go to the Bh Addon's server (press green then yellow on your remote), choose Addons download manager, then Picons Packages then at the bottom of the list you will find my Picon LCD skin.
Once you have that installed you go back into the same area (picons package) and then select the picons's you want to use depending on which satellite(s) you use.
Hello all,
You all here seem to know a lot about picons, can you help me with few things? I made a post on this forum but not much of replies im getting, so i will copy paste some things i need to know :
-what are the diferences between Picons, LCD picons and VFD picons.
-I managed to find out that if i enlarge the picon image then in channel list it shows nice, in Info Bar is Full Size but down on the receiver it does not show right, if i make the picon image smaller then down on the receiver looks almost ok not covering the other icons, but up in the infobar its small and shows only in one corner. If i dont put in picon then i have only the channel name but id like to have picon on receiver. I have downloaded the picons for Thor 0.8W what im moslty watching, the picons where 100x60, i made them 220x132 and placed it in root/picon folder.
Im Using Black Hole 2.1.7 MultiBoot on VU+ Ultimo receiver, the skin is the default one that comes with the 2.1.7 Can anyone help me how to get this right?
Thanks
Hello all,
Q 1) -what are the diferences between Picons, LCD picons and VFD picons.
Thanks
A 1) - Your STB isn´t able to display LCD picons, because has not an LCD, but an VFD!
Picons - are for infobar and channel list - If you use Matrix10 Full HD Skins the best for fit are 220x132 size.
I don´t have a ultimo to help you ... but you can put them on: /usr/share/enigma2/piconlcd, but it is recommended to install them in /media/usb/piconlcd
If they display correctly as 100x60 on VFD ... use this size for VFD
and put the 220x132 on /media/usb/picon, so:
Note: On a usb pen drive you have:
/media/usb --> one folder named <picon> and other folder named <piconlcd>
Thanks for the answer and help, i have tried to put the picon 100x60 into media/usb/picon and the 220x132 to usr/share/enigma2/piconlcd also reversed way the 220x132 into media/usb/picon and the 100x60 to usr/share/enigma2/piconlcd and again the same, i have either the picon on VFD show too big and not showing properly but in infobar and channel list show correct, or on VFD is ok but then in infobar is small and placed in upper corner of infobar in small size.
Post here your skin_user.xml
file from /etc/enigma2/
