Vu+ UNO Firmware Upgrade
Yesssssss, Thanks guys it works, if have some one from England commanded let guests will treat Fosters beer. I live in Northampton. BIG,BIG,BIG,BIG THANKS- U ARE SIMPLE THE BEST. THANkS AGAINE from 1 happy Bulgarian man.Cheers
:thanks::clap::yahoo:
I've tried run this update on OpenPli, unfortunately don't work. I have still lack of singnal on 13.0°E TP 11411 27500 H FEC 5/6 (DVB-S2)
Nobody has problems with plugins audio?
FPGA update is done and
after new drivers update I have no sound with:
1. Merlin Music Player
2. My Tube Player
3. Shoutcast radio
For test I reinstalled old drivers (4 files) , restart and plugins sound is back as normal.
Then tried again with new drivers, restart - no sound with these plugins.
2. My Tube Player
3. Shoutcast radio
It seems there are issues with some audio codec.
However, we have to remember that we are talking about beta drivers and I think they will be further fixed before their final release.
Problem solved on 13.0°E TP 11411 27500 H FEC 5/6 (DVB-S2).
You have to update both drivers and FPGA.
To update drivers, download the attached files unzip it and overwrite the files you can find into /lib/modules/2.6.18-7.3/extra
After the upgrade, you have to restart your UNO.
which method we do the update FPGA via internet or via usb keys
which method we do the update FPGA via internet or via usb ****
I think you can download the file for FPGA on your box (into /tmp folder for example) and then launch the FPGA Update Plugin.
2. My Tube Player
3. Shoutcast radio
As answered by Mito, the new drivers have some problems with audio codec. The issue has been reported today to Vu+ after some other tests with multimedia files also.
There are still a problem
bug in Asiasat(100.5E)
at some TP :
12582/40700/v
12642/40700/v
12702/40700/v
all: dvb-S2/8PSK
:closedeyes:
New beta drivers update 2011 11 03​
Fix No sound problem in media playback​
Thanks to Tamaki for the guide to install new drivers:​
First of all make a backup copy of the corrent drivers, copy all the files in​
/lib/modules/2.6.18-7.3/extra​
When new drivers comes out, take tar.gz drivers file and unzip all files in​
and replace old drivers.​
Than reboot your dec, that's all.​
If image reboots correctly new drivers are compatible with your image, if image doesn't start it means that the drivers are not compatible and you have to wait for a img upgrade.​
In this case to go back to old drivers, just connect with ftp and copy the drivers you backup before to:​
