Vu+ Uno4K Tested for You !!!
You can mount a usb stick as /hdd, this will work for recordings (although I have only tried a couple of minutes, not complete programs), however you can not use it for timeshift with BH as that image requires a real hdd to be installed, with OBH I don't think it bothers to check if you are using a real hdd.
thanks for the answers. I require timeshift as well so if anyone can confirm they have that working with usb via obh or similar that would be appreciated (else I may just get a 2se as a Solo 4k is a bit pricey).
Sent from my SM-G925F using Tapatalk
Seems good receiver but whats the cost if they have had any display on the front
Moreover VU+ support used to be good in the past but now they dont bother to address the issue so buying any VU+ product is big risk
You have me reconsidering now if the support is poor now. Who does offer the best support for their boxes then?
It's a very good box.
If you measures the goodness of a box only from the presence of a display you have took the bad approach.
A display is not the solution for all problems or user needs.
The display shows infos during use or clock in standby..... it's so reductive to measure the validity of a box only from display.
At the moment, Vu+ continues to support ALL their boxes without limits.
Other brands have discontinued support for their old boxes.
This is a thing to consider and evaluate the strongest of Vu+ company instead other brands.
That is good to know. Thanks for the reply.
hello
Can someone help me how to activate the drivers for wifi usb adapter on Vu +uno 4k?I flashed the blackhole image 3.0.3.a kodi and have tried 3 different adapters of tp link but none is working.
thank you
How much of an issue is ARM vs MIPS support? I have read some comments from a Solo4K owner who says it is an uphill struggle with it being ARM based.
Solo4K was first ARM 4K box on the market, and it has been over 12 months now since it was released.
Support of ARM is getting much better and it's clearly the future as other manufacturers are now switching to ARM for there new boxes too.
Just wanted to update and say I have had one for just over a week and after a small learning curve seems to be setup and working beautifully so far. Great box.
If you are talking about Netflix (or similar) the answer is negative.
An android application don't work in E2.
It's an iptv server with channels H265. Work in Android very well. There is not a plugins for watching this in vu+ uno 4k ?
Is there a possibility to instal a hard drive inside ?
If i see that, it is possible,
http://www.vuplus.fr/recepteurs-vu/2130-vu-uno-4k.html#/disque_dur_integre-avec_un_disque_dur_500gb_installe_59/pre_installation_logiciel-image_d_usine/vu_uno_4k_tuner_1-vu_uno_4k_1x_dvb_s2_fbc_twin_tuner_linux_26900
but i don't read this in this post.
no, there is no space for internal hdd
Ok, but it possible to add one on the vuplus board and the price changes.
