Vu+ Uno4K Tested for You !!!
There is no dvb-s2x support for Uno4K.
The tuner looks like it will support it, but the chipset used in the Uno4K does not look like it does.
It is possible that Vuplus might have a work around for this later on (purely thinking out loud here), but the Ultimo4K uses the same tuners, so it might be that the Ultimo4K will support dvb-s2 but not the Uno4K.
Lets just forget about DVB-S2X for now ... does the vu do 16 or 32 APSK DVB-S2?
I honestly don't understand why manufactures don't specify what DVB-S2 modulations it can handle ...
Find me a transponder in europe, and I will test.
HI
I bought the Vu+ uno 4k
has problem no many Image of me this device I have time to change my device to DM 900UHD
is new box you have to wait is already 3 image and more coming soon , like all vu plus range , dm900hd go be the same with lest images
OpenAtv have KODI 16.1 in the feed on plugins- extentions -KoDI play direct,after instalation ,works properly, but uses the media player from E2. *****? U must google for more:chair: , - ARM ***** for VU+. On my box is functional, just configure it by yourself. Or copy your config.:shout:
Banned.
Read board rules next time.
open atv
I did "nt find kodi for open atv
The problem I can not find her kodi and oscm
Banned you too.
Read board rules is too hard?
Thanks for the helpful review. Is it possible to record to an attached USB device on the Uno 4k?
If you think about USB harddisk ,is possible.
I have not tested but USB stick is likely to slow for this purpose.
You can also use a network drive.
I have My Book Live | WD (cifs recording)
