win tv -hvr 900
doah!! *-(
I installed the driver ok.
When i scan, I get 0 services found?
Reboot your box and then post the output of "dmesg" command my friend.
I haven't this kind of device actually (it's near Milan now :( ) and I need all kind of infos possible to make it works :)
meaning...?
does this mean your drivers wont work Angelo
drivers should works for both versions of HVR900 but I need to study the errors located into your report. There are common errors and Google shows more people affected by same problem.... It's positive to find a fast solution :)
i have the latest version of bh.
linux tv shows that the device should work.
ill leave it with Angelo and hopefully you will get it working..
I've changed a little the driver for your device.
Please disable it, re-download, re-enable and perform the "dmesg" only output.
Thanks again!
same here. downloaded driver 1h ago. zero services found with manual or automatic scan.
here it is my dmesg output. Looks like I have a R2 version.
Hope this helps
Hope this helps
Yes. You have R2 device with Micronas tuner. It's correctly detected.
I will try to make more debug messages to know there are the rpoblems.
I've modified the driver package.
Please re-install it from server (disable first the current tuner if it's active....) and re-post a "dmesg" output.
Thanks!
I disabled the old driver (EM28xx) and downloaded the "Haupauge HVR900 driver by Blackhole team.
I rebooted to activate and it was shown "working", though it still shows EM28xx and not Haupauge hvr9000?
Is there a way to clear the folder containing the downloaded drivers on the box,?
I too tried to scan but NO channels found.. I will upload a dmesg.
I have uploaded the new package for HVR900.
Test and report with a "dmesg" output only if the device now works or not... and SPECIFY the box you are using!
On my Uno the HVR900 works regularly: has found 311 services with the portable antenna :)
