Working 1 channel plugin
Hi Yummer,
Hope you can help.
I am quite confused now with regard to the 1 channel plugin.
I used to be able to get it, but now with the overwrite 1 and 2 and then the replacement py files I seem to have lost the plot.
I have now deleted (via FTP) all files associated with the 1 channel, I would be grateful if you could assist a newbi by giving instructions from scratch
on how to load this terrific plug in on a 'step by step' basis
Sorry to be a pain.
Best Regards,
John
Hi Yummer,
Hope you can help.
Sorry to be a pain.
Best Regards,
John
Just do the first post m8... Then just the last plugin.zip file that I uploaded m8. Then restart enigma
Hi Yummer,
Still having problems.
Webt to first post as you said and did the following :-
Instructions......
install ipk
ftp overwrite1 to usr/lib/enigma2/python/plugins/extensions/1channel
ftp overwrite2 to same location
I then loaded the last plug-in zip file that you uploaded to usr/lib/enigma2/python/plugins/extensions/1channel..................One Channel is there but still says 'sorry nothing found' ????????
Am I doing somethig wrong somewhere?
Cheers,
John
Hi Yummer,
Instructions......
install ipk
Cheers,
John
Have you restarted enigma after you've copied files?
Try again m8 uninstall everything. Install ipk first. The stb should reboot anyway after this. Ftp over the both overwrites (these have to be unpacked using winrar etc). Then unzip the plugin.zip....this contains a .pyo file and ftp that over. Restart enigma... Mines working ok so not sure what you've done wrong... Maybe wrong order or summit buddy?
Same problem here lads.
Uninstalled current 1channel, rebooted.
FTP'd IPK file to temp and installed 1channel, rebooted
Unzipped Overwrite1 on laptop then FTP'd to correct location per post 1, rebooted
Unzipped Overwrite2 on laptop and FTP'd to 1channel folder, rebooted
Unzipped new Plugin.zip on laptop and FTP'd to 1channel, rebooted
Plugin is accessible but there's no films/tv shows listed at all.
Any advice lads?
First delete manually old plugin 1channel.
Copy folder "1channel" via FTP in:
usr/lib/enigma2/python/Plugins/Extensions
Restart Enigma2
can someone try this for me please as havent got time atm
@yummer
first of all thanks for all your trouble in trying to help us out. I also wish you and those around you a very prosperous new year!
As I had said above it is working but rather in limited amounts of links etc. Could not get any to work on Films but seems o k on some tv. The version you had given prior to this one was much faster.
@yummer
possibley try the other one ive just posted see if that helps? im in uk so other one is blocked
