Working 1 channel plugin
thanks for reply Robocop
I never use this plugin before & iam living in uae,Dubai
I installed the plugin and I overwrite the 2 files as it was shown but its gives me error when I try to browse any thing in the application
I see a lot of changes happen to the 2 overwrites files , can u please provide me with the latest 2 overwrite files.
thanks
Morning.As I live in the UK I have to use a private proxy for 1channel as it is blocked over here so I don't know what files actually work for you.Mine has been installed for quite a while with no problems.I have found this file in some stuff on my computer.Just extract the file, install it by ftp to usr/lib/enigma2/python/plugins/extensions.Make sure you have deleted any old versions that are there first.After you have done that restart enigma.It should now be in your plugins.If it doesn't work you will have to go down the private proxy route.Good luck!!
The proxy points to primewire.ag which is banned in the UK but ok in Dubai. Mohammed you need the original 1channel which should automatically point to primewire. ag without alteration. Theres versions on this site by searching. Good luck.
thanks a lot for the response Robocop Its working without error but nothing is opening , that's coz of the proxy
also thanx for McrRed, can u provide me the original file so I can try it which is working with primewire
Hi Guys, not sure if this is the correct place for this post but it seems inline with what you guys are chatting about.
Im trying to configure my duo2 with the BH image to use a proxy with 1channel but cant work out how to do it. could some one puppy walk a newb through this (probably REALLY basic) procedure?
Morning mate.Take a look at this and see how you get on
ok cool, ive followed the instructions. I got the domain and the htaccess file sorted and when i navigate to my new domain name i get the primewire . a g home page.
My stumbling block is that i dont have a channel1 _source file in the etc / tsmedia folder. However there is a file called proxy _ links within which is the following line/block of code
(i have had to make sure the site doent flag the below text up as a link due to the restrictions on posting links as a new member so ive put gaps in the url)
channe l1$p roxy2 $ht t p : / / w ww . prim ewi re . a g/
so i changed the first section to
channe l1$p ro xy2$ht t p : / / www . m yd om ain. net/
this doesn't appear to have worked, when i got to TSmedia plugin via GUI and select NET TV then 1Channel Series no results are displayed.
Any guidance or advice would be much appreciated.
sorry forgot to add
Just uploading the htaccess and proxy.php files to my new domain directory displayed only my directory contents when navigating to my new url so i duplicated the proxy.php file and renamed it index.php, this allowed the primewire homepage to display under my new url but none of the links on the page work.
thanks
IVE DONE IT!
Ok so i forgot to press blue button in 1channel app (via tsmedia plugin) and change proxy source from primewire . a g to proxy2 and its wokring fine now.
Thanks for the help and i hope someone else can learn from my stupidity.
I have followed all your instructions Robocop but I don't have tsmedia on my solo 2 , I might have deleted it by accident , I have tried to install it to my ftp an also directly from the add ons in ******* , can you give me any advice my head is chocker lol !
Hello mate.Ask the same question in the TSMedia section and I'll get back to you as this is for 1channel help
Third party panels like the one you have installed is not yet supported or wanted here.
Hi, I did this ages ago and 1channel worked for months. However it stopped recently. I reflashed openvix image and installed latest TSMedia (9.5), typed in my proxy url (through 000webhosting which works on laptop for primewire.ag), the movie lists come up and picking a movie I get the novamov.com or videoweed.com etc list but selecting them I get the 'Error:Addon...etc message. Any ideas, thanks.
I have a web host proxy to access primewir.ag on my laptop, (vu solo with openvix and tsmedia 9.5), in 1channel under set up I typed in my proxy url and get film lists, and on selecting a film get the list of novamov.com, videoweed.com etc list but just Error:Addon... message. Please advise, thanks.
Hello mate.I currently use XBMC on Blackhole 2.1.4 and my proxy works perfectly on that so I uninstalled TSMedia as it was very hit and miss.Unfortunately you can't use that on Solo but I will reinstall it and have a bit play and see if I can get it to work and I will post my findings.
