Working 1 channel plugin
Hi Yummer,
All working here as well.
Many thanks for your assistance with this and thank you for your assistance over the last Year(s).
I would like to take this opportunity to wish you and your family all the very best for the new year.
Please keep up the good work, it is very much appreciated.
Very Best Regards,
John
Hi Yummer,
Very Best Regards,
John
Thank you... All credit goes to author not me though John m8... I've only found and shared... All the best buddy ;)
Its all to do with the proxy... I'm afraid it looks like we're on a losing battle with this unless you create your own private proxy and its a little beyond me as it probably is with most of us users with no programming experience
Hi Yummer,
Thank you for your reply.
I have no idea what 'proxy' is and if it's to do with progrmming then that is completely beyond me.
We can only hope that the creator of this 'plugin' can work his magic again.
Regards,
John
First delete manually old plugin 1channel.
Copy folder "1channel" via FTP in:
usr/lib/enigma2/python/Plugins/Extensions
Restart Enigma2
can someone try this for me please as havent got time atm
Hi, I'm in SPain, First addon I actually install on my box via FTP
used this file
works great, thanks alot
I cannot get this to work. Followed all instructions to the letter but nothing is ever found. How do I add the urls in the urllist.txt file
Mate you need to set up your own private proxy and you need a decompiled py file so this no longer works if your in uk
Can someone pls let me know if I can get an updated plugin. I am outside the UK so no blockout.
thanks for any answer.
This plugin still works. As far as I know if you're outside the UK then the versions towards the beginning of the thread before all the proxy discussions started should work (summer 2013 iirc)
