DavidV
I allready have a Yarvik 10.7 inchWhat about buying a 10" android/ipad![]()
There is nothing you can do, it's so for everybody, it's not a problem of your box, the LCD was not designed to be a television screen, I can suggest you not to activate this completely unuseful functionality that uses a lot of box's resources...video on lcd of dou2 freez and not show prefectly
Thanks. Took me a minute or so to find it.Use the mode IDLE in the LCD4linux settings to configure the LCD appearance when the box is in standby.
I have uploaded a config file for someone here, you may try it.Hi all,
Can someone help me to have such simple display as in the officail Vu+ web site (picons & weather)?
Many many thanks in advance
Amine
Very nice!!!I thought as setting up the LCD display on the Duo2 is much easier than it was for the Ultimo, that members could post up there layouts for others to use.
The best ones will be added to the BH addon server (if you would rather they are not added to the server, then just make it clear in your post and we won't add it).
Please post a screenshot to show how it looks.
The file you need to upload can be found in /etc/enigma2
Here is mine to kick things off with:
To get the background to work, just add the included folder to /media/usb
Hi,Why not try your pc/tablet/phone browser instead, and then perhaps buy a cheap tablet permanent ??
http://www.agfaphoto.com/appc/content_manager/page.php?ID=195894&dbc=028fe893da68da0c8433cdd5bf505b7
I do speak German rathe "halfgood" but very tricky to follow teh Germman instructions.read this thread and follow URL in #99
Your VFD skin is just what I'm looking for... Could you tell me where I can download it, of could you upload your VFD configuration file? Thanks.
Hi all
I am having issues getting the picons to work, I have installed the picons to /media/hdd/picon I have also changed the path in LCD4Linux and rebooted the box however it is not working. it dosent show the picon just the name of the channel, tried various lcd configs here but none make a difference. anyone have any ideas. Thanks
