LCD4LINUX Solo4K
LOL! Matrix10 is my favorite administrator here, who started this thread.
As for Vu+ Uno 4K, I guess you'll have to look elsewhere. These are for Solo 4K only, as suggested in the title.
My configuration...
Install LCD4Linux plugin and then copy both files in /etc/enigma2/...
Image file (wall.jpg) must go in /media/hdd/backgrounds/wall.jpg
:yahoo:
  • LCD4Config.zip
    LCD4Config.zip
Unfortunately, the LCD for Ultimo4K is 800x480
I do not know if anyone can configure it for Ultimo4K.
In addition, we need info if tested on other boxes.
If you scale this one to 800x (original is 400x) the other elements must be positioned/scale...
I can do this if I have an Ultimo4K or connect to an WebIF of a person which have Ultimo4k (or Team Viewer)...
Understand this is for solo 4k (post 85) and you have test .
We can put on the BH server after small change path for background /wall
because some user do not use any HDD or USB.
For Ultimo 4K it takes a bit more than the scale.
Also LCD Skin Coding (skin_user.xml) is not good for Ultimo 4K LCD size.
When I have time to look at it if someone else does not do it.
All you need for LCD VU+ solo 4K its on blackhole server:
First download LCD linux V4.7r4 Arm and install
Next download LCDlinux config Solo 4K and install
Restart your receiver and you have this:
The way the lcd works is different between BH and OBH (oe-a images in general), always has been for some reason.
BH will work with 32bit and oe-a / pli does not, but oe-a and pli will work with 24bit and BH will not iirc.
For uno4KSE BH3.0.5 what is better 32 OR 8? Thank u.
hello
please help me
I don't have access to blackhole server to download plugin with dependencies
when i I want install it manually get errors for dependencies:* python-imaging*
can some one help me?
THE BOX SHOULD RECOGNIZE THE dns ON, ITS OWN IT USED TO BE THERE TILL 2.1.7 then it was no longer automatic on the images after 2.1.7
