TSmedia enigma2 plugin by mfaraj57
hi,
im new here...
having trouble with installing ts media. I have no idea as to how I can install ts media on to my device.
if any one could help me please, been stuck for a very long time and no one would help me
thanks
Emad
hi,
im new here...
thanks
Emad
Hello mate.What device do you have?
no im not blind, you don't need to be rude.
all I was asking is for some support and I didn't koow that is was a clone,
I just checked the box its got vu solo onit. does that still make it a clone
I installed the latest version and ITV1 and bbc one (the only 2 that I tried) stops playing in about 5-10 minutes..
I am using Vu solo genuine: blackhole 2.0.9
and tsmedia 4.9
any ideas ?
Also tried all possible versions of tsmedia on blackhole 2.0.8 but still same problem :S
tbh some parts of tsmedia work well ,others don't, the latest version is same v.5. There are many reasons usually the stream source is a problem ,they change too quickly, some sources are geo locked, others will work ok then die at peak timescos source can't cope with demand. i like usingts media and constantly follow it's progress, as said the new one isn't great, BH for me is best image for tsm, found it even more flaky with others,
Did anyone update to 5.0.2 and was successful....because I had no luck and had to go down...tryed more than once..Note from 5.0 to 5.0.1 was Okay.
Thanks
version 5.1 has issues with streaming on certain addons, version 5.2 just won'y open ,gsod crash.
the ver5.2 probs are well reported on dev forum thru different users, images, boxes, so hopefully it will be addressed
Thanks to all for your quick respons....and hope that this will be solved,because am sure that a lot of you agree that this has always been a very interesting plugin,not to say THE BEST...cheers to the author
I have just updated to TSMedia5.2 & using BH2.09 image, I just get GSOD when i try to open.....it seems we are all having the same problem. I will have to go back to 5.1 as at least that version is working.
