TSmedia enigma2 plugin by mfaraj57
[quote="Please help, location and file name of the 'userstream.xml ? '.[/quote]
I open DCC
go to Commander
dubble click map: ETC
dubble click map: TSmedia
there you find "userstream.xml"
is there anyway i can fix 1channel for the uk
hi mate,
short answer ... yes
use the tut and files below.
not my work but a huge thanks to those whom it belongs too.
hope this helps mate....it did for me
thanks for your help but in 1 channel settings it says select proxy source and i cant
change it can you help
if your proxy in right way you can select your proxy from settings,be sure your are using latest 4.9 beta 9 version
Tthis is example
channel1$proxy_1$proxy_link
replace proxy_link by your proxy link and append the line to the file /etc/TSmedia/proxy_links file
start box and from 1channel blue settings select proxy_1
hassanen please tell me what you mean by: [QUOTEftp tsmedia ipk to tmp folder.]
what is ftp and ipk
Sorry but I am a beginner.
Thanks anyhow for your action sofar.[/quote]
hi ftp means to send a file to (or from your box ) , I use dream control center to ftp files but you can also use vu control center . so what you need to do is download dream control center and open it , after that there is some setting up just to get it to connect to your box , you will need to have your box connected to your broadband router of course .
once you have downloaded dream control center and set it up , you can go about using it to install tsmedia , however this thread is not the place to discuss this stuff . I don't know if there is tutorial section here where you canlearn , but if not send me a pm and ill be happy to help you install tsmedia .
In Dutch we have a saying like: 'waited for some time, kept silet and yet received!
Thanks for your reply; it is clear to me now and I will work on it now.
In case I have further questions on this I will contact you.
Thanks again !!!
Verstuurd vanaf mijn GT-I9100P met Tapatalk
I open DCC
go to Commander
there you find "userstream.xml"[/quote]
Thank @chevrolet for your information. I do not use DCC, but I have checked the etc/TSmedia and subdirectories, I did not find the file userstream.xml or similar file, I did do a few test channels, these channel do appear in the section of user-stream in the TSMedia's page. Do you have any idea? Did I do something wrong?
I open DCC
go to Commander
Thank @chevrolet for your information. I do not use DCC, but I have checked the etc/TSmedia and subdirectories, I did not find the file userstream.xml or similar file, I did do a few test channels, these channel do appear in the section of user-stream in the TSMedia's page. Do you have any idea? Did I do something wrong?[/quote]
Hi mate,
I edited the following files which are located in the TSmedia folder: channel1_source and proxy_links.
hope this helps
[thank @chevrolet for your information. I do not use DCC, but I have checked the etc/TSmedia and subdirectories, I did not find the file userstream.xml or similar file, I did do a few test channels, these channel do appear in the section of user-stream in the TSMedia's page. Do you have any idea? Did I do something wrong?[/quote]
i checked again my VU+ duo with BH and can only find file "userstream"in etc/TSmedia.
The stream you add is this one playing
in TSMedia?
@eattheliving,
Look at this link maybe will work for you:
http://bbs.dreamoem.com/showthread.php?5839-HowTo-Add-your-stream-link-to-bouquets-by-TSmedia&p=23759#post23759
@eattheliving,
thanks mate. does this work for the sports streaming in the sport devil folder on tsmedia matey?
I have already got all the other movie/series ones working via proxy setups already
bonsoir je Touche Un peu sur vu + MAIS je la comprend, plus je tunisienne qui fonctionne aidez moi a resoudre se souci
j'ai un vu+solo pro et ces TSMEDIA 4.9 BETA9
good evening I Touch A little on VU+ BUTI understand it, more I Tunisian Which FUNCTION help me one to solve concern
I have VU+ solo Pro and THESE TSMEDIA 4.9 beta9
Thanks for this great plugin.
I got it to work with the movies, music and some streamings services like FilmOn, checked the UK channels on FilmOn but the audio was delayed like ten seconds.
When I try the IPTV sections I can see the list of services but when selecting them I only get a blank screen. I have waited a while but nothing starts. No matter what service I choose same thing.
I got the movies working thanks to the great instructions provided by EATTHELIVING, thanks!
Jan
Jan
a pleasure matey.
I just need help with the sports devil streaming... help anyone????
