TSmedia enigma2 plugin by mfaraj57
I just red the items on "TSmedia enigma2 plugin by mfaraj57" and because I am a beginner and eager to watch movies, I have (may be stupid) questions and they are:
  • do I have to install the TSmedia in addition to BH image and
  • can I install it like I installed the BH image ?
I hope to receive answers to these questions , so I will be able to proceed.
Thanks in advance
ftp tsmedia ipk to tmp folder.
then on your blackhole go menu>setup?software managment> install local extension and you will se tsmedia ip press ok and done.
hassanen please tell me what you mean by: [QUOTEftp tsmedia ipk to tmp folder.][/QUOTE]
what is ftp and ipk
Sorry but I am a beginner.
Thanks anyhow for your action sofar.
TSmedia 4.9 beta2
-The plugin rewritten completely and folders tree rebuilt completely ,the code managed in different way,many extra code lines removed,favorites management now is more better
all these changes made to accommodate new updates and new plugins will be added later
also i tried my best to reduce the size of the plugin and in this 4.9 beta2(2mb) the size of the plugin reduced nearly 1 mb which is very good especially for limited capacity boxes like dreambox
although not my target but i noticed the plugin and menus are faster and i thought it is just illusion but members confirmed that
also many not working plugin fixed like Swedish subtitle site(dream),arabic(bokra) and others,small icons specific for each plugin added instead movie or tv icons
helenic tv channels few are working but most not for reason i do not know,the links extracted from the site are right but not working
advice to remove the previous version first before installation the new beta release to avoid possible interference of old folders with new folders
also presence of xbmcaddons plugin may conflict with TSmedia especially with plugins imported from xbmc
to remove old version either manually by any ftp software or from *******-tools1-uninstaller-remove plugin folder
This release only for oe2.0 images(coming version 5 will be for oe1.6 and oe2.0)
available through *******/Ts addons/TSmedia_library or from updates-library from previous versions
Thanks to Mfaraj57
Nice to hear you again. You have done excellent work with plugin that really provides a lot of features as pure Smart TV system. I do hope that many Enigma2 users appreciate it and many thanks on your work.
it is mfaraj57 work he is the author of this plugin
i just share this very good plugin with Vuplus Community
best addons very good work ,but i have a litle problem with spordevil addons no play video the last tsmedia 4.7 play perfect why ; (solo2) pls mfaraj57 fix it if you can is best addons for xbmc another addons work perfect thanks again great work..
Thanks for the plugin uses BH 2.0.8 VU Duo but last TSmedia 4.9 beta2 is not installed on the image and does not work and the old tsmedia 4.7 works well
I know that this plugin is mfaraj57 work. And I repeat, nice to hear mfaraj57 again. He has done excellent work with plugin that really provides a lot of features as pure Smart TV system. I do hope that many Enigma2 users appreciate it and many thanks on mfaraj57 work.
TSmedia 4.9 beta3​
-karaoke added to radio&music section
-akoam movies to arabic movies
-fixed HasBahCa m3u(thanks for HasBahCa)
-fixed minor bugs
available from *******/ts addons/TSmedia and TSmedia_library
not available through autoupdate
only for oe2.0 images and openpli 4.0,3.0
@sat gr . Thank you very much for your uplaoding the file. Do I need to uninstall the old version (4.9) before install this version, or it can be installed directly? I did read your note on the Version 3.9 beta 2. I just wish to get a further comfirmation.
