TSmedia enigma2 plugin by mfaraj57
Now i have 4.6 but still 1channel very often doesn't work. This is only feature that i use in this plugin.
Sent from my Nexus 7 using Tapatalk HD
Can someone pls help i am have trouble installing tsmedia on duo2 BH207.1.2 i manually intalled ts 4.6 but it does not show up anywhere in plugins and cannot uninstall it, i tried to instal diferent ver 3.5 -4.5 but it say it cannot downgrade from 4.6.
I tried but there are some errors (attachment )
When 1channel has problems i can't load episodes to choose at all. It doesn't work very often.
1) go in to updates
2) Press blue for Library
3) Scroll down and highlight Tsmedia 4.6 click ok (A tick should appear)
4) Press opk update
5)Press Yellow and force install
Hi, Shilev. I have several times with installation problems, but I cannot hold the message screen. How did you do it?
It's because of the illegal nature of the feeds that supply this plugin which are now being blocked by the uk internet service providers.
you can read more here
http://www.xbmchub.com/forums/1channel-plugin/15520-primewire-blocked-uk-end-month.html
There is a fix out there if you look for it.
I'm not from UK. Sometimes 1ch works,sometimes not,there's no rule. I believe that problem is in plugin.
With Terrafilms dont' start nothing and when I choice for all titles I'm waiting severale time and don't start or block.
Guys, I am thinking of installing this on my new Duo 2. Just wondering if it contains any illegal stuff, just to avoid hassle.
cheers
Certain things could be legal to watch, but illegal to distribute (link to streams and servers).
But I guess it all depends on which country you live in.
I have been reading all the comments about this plugin and feel some of them are a bit unfair, instead of moaning about this and that not working please try to remember that some people have given up their time to
make this great plugin.
There is a huge amount of stuff contained in it, so stop moaning and do like I do switch to something that does work if the first thing does not work.
FOOTNOTE TO MAKERS:- THANK YOU FOR A GREAT PLUGIN
is this plugin killed? the authors website is gone
http://tunisia-dreambox.info/ ?
was the best plugin ever for the enigma2 boxes
Edit by angelofsky1980: no live links !
TSmedia 4.7
TSmedia 4.7
-HellenicTv Greek TV channels
-Simplymovies-films and tv series
-earthcam-live cams from all the region in the world
-sportsdevil-endless live sports channels and many other non sports channels
all plugins imported for xbmc plugins although import to enigm2 not simple and consumed effort and time,the thanks for the genius coders of the plugins
many links in sportsdevil take longtime to open mostly from the source but i will try to fix,errors and crashs may happen because the plugin not well tested and this is just the beginning for importing large numbers of xbmc plugins to enigma2
The difference from xbmcaddons for PCD that he used the xbmc GUI also and this may slow the exploring the menus also alot of crashes and and errors without notification,the only advantage of xbmcaddons we can use xbmc addons with simple editing but importing xbmc addons for enigma2 in my way need more effort to modifiy the original code but more satisfaction for users
for now only for oe2.0
no available through ******* or autoupdate
by telent after moving the ipk to tmp
opkg update && opkg install -force-overwrite /tmp/*.ipk
Thanks to mfaraj57
TSmedia 4.7​
TSmedia 4.7
Thanks to mfaraj57
Thanks , we like the plugin and like your kind upload and supports
TSmedia 4.7​
TSmedia 4.7
Thanks to mfaraj57
Is it compatible to BH 2.0.7.R2?
Thanks @sat gr . I have tried the TSmedia 4.7 last nigh. It is very nice, I like it and will spend some time to play it. We all wish you could update the plugin from time to time whenever it is available. THANKS again.
for testing
TSmedia 4.7 beta3
- add netmedia justintv,fixed bugs
-fixed some bugs
-recoding of teledunet(the site may be down now)
important to do opkg update before installation of the package
opkg update && opkg install -force-overwrite /tmp/*ipk
