TSmedia enigma2 plugin by mfaraj57
I have tried to attach file many times it doesnt seem to go through
can download here:
http://www.4shared.com/file/CxsNxg2N/enigma2-plugin-extensions-tsme.html
for testing
TSmedia 4.7 beta3
important to do opkg update before installation of the package
opkg update && opkg install -force-overwrite /tmp/*ipk
Hi, @hasman. Thank your for your uplaod the beta 3 version. I usually update plugin from inside of BH plugin installion interface. I believe that the above command is a telnet command. what is exactly means of that command? It looks like to update all ipk packages in the tmp folder and force them to be installed. Am I right? When should I use the command, I means before uploading the beta3.ipk to the tmp folder or after?
Hi pls help me i have ts media 3.91 to pli and i try to update but when search for update i have
green page and reboot
thanks
I hope someone can help. I just can't get the TS Media Plugin to load properly. I have Blackhole 2.0.2 I've loaded it almost ten times without success. Here is the log.
BlackHole 2.0.2 bm750
bm750 login: root
Password:
root@bm750:~# opkg update
Downloading http://feeds.vuplus-community.net/3rd-party-settings/Packages.gz.
Inflating http://feeds.vuplus-community.net/3rd-party-settings/Packages.gz.
Updated list of available packages in /var/lib/opkg/official-3rd-party-settings.
Downloading http://feeds.vuplus-community.net/2.0.2/bm750/all/Packages.gz.
wget: server returned error: HTTP/1.1 404 Not Found
Downloading http://feeds.vuplus-community.net/2.0.2/bm750/bm750/Packages.gz.
Downloading http://feeds.vuplus-community.net/2.0.2/bm750/mips32el/Packages.gz.
Collected errors:
* opkg_download: Failed to download http://feeds.vuplus-community.net/2.0.2/bm7
50/all/Packages.gz, wget returned 1.
50/bm750/Packages.gz, wget returned 1.
50/mips32el/Packages.gz, wget returned 1.
root@bm750:~# opkg install -force-overwrite /tmp/*.ipk
Installing enigma2-plugin-extensions-tsmedia-oe2.0 (4.7-beta3) to root...
Installing gst-plugins-ugly-asf (0.10.19.1+git4633+981912f-r0) to root...
Downloading http://feeds.vuplus-community.net/2.0.2/bm750/mips32el/gst-plugins-u
gly-asf_0.10.19.1+git4633+981912f-r0_mips32el.ipk.
Configuring librtmp1.
Collected errors:
50/mips32el/gst-plugins-ugly-asf_0.10.19.1+git4633+981912f-r0_mips32el.ipk, wget
returned 1.
* opkg_install_pkg: Failed to download gst-plugins-ugly-asf. Perhaps you need t
o run 'opkg update'?
* opkg_install_cmd: Cannot install package enigma2-plugin-extensions-tsmedia-oe
2.0.
* pkg_run_script: package "librtmp1" postinst script returned status 1.
* opkg_configure: librtmp1.postinst returned 1.
root@bm750:~#
Double Dutch to me, so I hope somebody can point me in the right direction. Much appreciated.
I have installed the TSMedia 3.7. It is poweful and many functions are intrerest. However, there are somethings which do not seems work properly for me. I am not sure whether I did not set the plugin properly or there are some bugs, please help!
1. The server update can not be done.
2. When using the live world cameras, very often ended with a system crashing and a green screen.
3. When I save some streem into my fevourite, the saved url and channel name cannot be download by Dreambox Edit properly (any space of channel name is replaced by %20, and many xx%A, or xx%B such characters are inserted into the url such as 'http%3A//zb.v.qq.com%3A1863/%3Fprogid%3D1975434150%20'. What can I do about it?
4. When I view a streem list, often shows an error message 'xml error', What it is? Can I fix it? I knew the nature of url (It changes from time to time).
Any suggestion please!
Does anyone other have problems with 1channel?
More often it doesn't work than it is.
I have bh 2.0.5, maybe i need last version.
Sent from my Nexus 7 using Tapatalk HD
Problem solved! I deleted favourites and put again the same series in fav list,now it's working very good.
This is becoming very annoying. After update on 4.8 version, 1channel again doesn't work for most of the time. Pls fix this if you have time, thanks in advance!
Also, search function doesn't work.
Hi!I have just installed above 4.9 tsmedia package to my vu+solo2.Is there something else I have to transfer in order for it to work as I have been using 1channel until recently and obviously that has gone for us at the moment so I would love to get another on demand service working.Thanks for any help in advance
