TSmedia enigma2 plugin by mfaraj57
i have an err gstreamer plugin not avaible help please
i to when trying to play 1920x1080 get the message gstreamer text/html is missing
but i cant find it in the library can anyone please help
Apparently its because the links are broken and returns a text error which cannot be displayed.... The author is working on fix.... This is also why GSOD on the icefilms plugin by the looks
Is there bug in plug-in TSMEDIA with Terrafilms? It's not possible to change page +/- on Terrafilm (italianfilms). Thanks
Can someone help me or guide me how I can install this plugin in my Vu solo2,since its not with the plugins downloads ...Thanks for your help
Download the latest file from this thread onto your pc. Using an ftp programme like DCC or vucc etc transfer file into tmp folder of your vu. In BH image then press green button>yellow button and select manually install ipk package then you should see it in list. Select by pressing OK on your remote and follow instructions.
TSmedia i get stream not found in all movies
now movie 25 stopped working
1channel links don't work for most of the time, icefilms doesn't work at all.i have version 4.5 but when i do online update on 4.6, after restart version is still 4.5.
Do you have similar problems?
Sent from my Nexus 7 using Tapatalk HD
Yes lot of links don't work... Author working on fix I think... Best person to ask for an update is @sat gr to see how this is coming along.
shilev as mentioned above:-
1) go in to updates
2) Press blue for Library
3) Scroll down and highlight Tsmedia 4.6 click ok (A tick should appear)
4) Press Yellow and force install
Restart your box and all should be ok
I tried but there are some errors (attachment )
When 1channel has problems i can't load episodes to choose at all. It doesn't work very often.
Is it possible to add Picons to the stream links after adding it to our favorite bouquet ?
I have tried several ways but failed can anyone guide.
if you have ts panel in your Vu+ go to tunisiasat addons and download from tsmedia library folder
the needed python file from error install message
yummer i'm not the author of the plugin mfaraj57 is the author
Yes I know your not author m8 but thought you could be a spokesman and possibly keep us updated if you know author ;)
Yesterday I installed TSMedia which seemed all OK but when i tried to open any of its IPTV, it would not open anything.
I uninstalled it and went back to 1channel which did not want to open up anything while it still opened up on another vu receiver that I have have.
Now I had to make a factory reset and re flashed image and 1channel works again.
Has anyone any idea how this can happen?
Thanks for any help i can get.
