TSmedia enigma2 plugin by mfaraj57
Mfaraj57 is there a way of locking adult content in the like of vidics and showbox whenever you go to recently added movies for example a lot of adult movies show on list even when adult content is turned off in settings
Thank for the very powerfull plugin. However, if the coders can add some function which is able to minimum the download-interface to a small windows in a place used can move, it would be very user-friendly. Also many users would be very appreciated if it can add a fresh fuction when user checks the downloaded file location. (currently, some files are sorted but not updated (refreshed). Any one has a way to contact the coder, please copy the wishes to them. I have no way to contact them.
Anyone else having problems downloading movies to hard drive. I can stream fine but when I select download it begins the download at 0% then immediately disappears. Not had this before
Garry,
When I had the same problem I did not get an answer on here but as soon as I upgraded to 8.9 all was working ok again. No help to you I know, but might need to be deleted and reinstalled?
Garry,
Tried deleting and reinstalling it. Made no difference. Will wait to see if next release makes any difference.
I have noticed another issue . when I return from the downloading page to the file list page, I need to press serveral times of the exit button. It used to press once. I am not sure whether there are some compatibility issue among BH2.1.5, TSMedia 8.9 and the Skin
Anyone else found that when watching NBC Sports Live Extra, they are always on a commercial break on TSMedia but not on Kodi...Hmmm Strange.
(Admins not sure if I am able to mention what I have...if I have broken the rules, please remove my post)
thanks man saved me lot of efforts trying to install iptv updater on duo 2
to Guly: t[if i want to add my list or a single iptv, how to do? ] to add a list you copy a m3u list in etc/tsmedia /m3u+open tsmedia
on the left list look for userstream m3u +ok an there is the list
