TSmedia enigma2 plugin by mfaraj57
Strange thing occures when I install TS om my BH image .
The instalation goes smooth and fine and plugin works as expected . I can watch moveies and series.
But after a while ( maybe even 2 days or so) . I try to start TS Media and get a small squire on top of the picture , the receiver locks completely
and I need to do re-start from the mains switch . Then it crashes every time i try to start plugin ....
The only solution is remoing the plugin from the list . It has happened several times with different TS media versions and different BH versions .
I use Pauli Neutrino layout , could this key layout generate the problem ?
HELLO
I HAVE DUO2 2 2.1.5 AND I HAVE THE SAME PROBLEM THAN DON ANDRES
ELSE WHEN I INSTAL AN OLD VERSION OF TS MEDIA, the menu is smal and i must be near the tv to make commande.
thanks for helping
Hello I updated tsmedia to the latest version but when I start the plugin the decoder crashes and no longer responds to any command.
vu+ solo se BH mage.
