TSmedia enigma2 plugin by mfaraj57
I do not have the crash log because the decoder locks (does not crash with green screen) and no longer responds to any command (exit, menu, channel changing etc etc) and the initial screen of ts media is not seen.
Non ho il crash log perchè il decoder si blocca (non va in crash con schermata verde) e non risponde più a nessun comando ( exit, menu, cambio canale etc etc) e
la schermata iniziale di ts media non si vede.
because the crash happened in individual bases difficult to know the cause without crash log or recording running enigma log to the file
some advices include installation of last version and changing of skin
Have updated to latest tsmedia running on vix apollo build 029 when trying to search for movies or TV shows crashes and reboots box any ideas?
Can anyone please explain to me what is so good about ts media? Nothing seems to work, genesis doesn't work, showbox doesn't work, ice films doesn't work
Unless I am doing something wrong
So what is working on tsmedia? I know YouTube works but the movies and TV shows doesn't seem to work that well
what works is partly about the software - partly about where you operate your receiver and partly about what your ISP allows - if something doesn't work it's usually and not necessarily the software
You have at least 30 movies addons,some not work for all but most are working,some blocked by your isp
example of working addons movies25,movie4k,icefilm,showbox,vidics,filmixk and many others
but sure if you want to watch specific movie you will find it somewhere
Is anyone having issues with the you tube app in ts? won't play anything and only shows a page/video saying you tube has updated and some devices are incompatible? I have the latest ts media. Giving a link to youtube . com / devicesupport
Anybody having issues with downloading movies or TV shows? download shows up on active downloads but then disappears after a second
Ive had this issue for the last 5-6 builds. I think its possibly down to the sites the movies are hosted on may be streaming only and don't allow there movies to be downloaded.
If I'm wrong I wouldn't mind some help solving the issue.
