Announcements All about PrismCube
Guys , which image is available for PC right now and are there any sites which explains the flashing method of this gear ?
I inserted a hard disk into Prismcube (NTFS) - when it is booting the display says that it is formating, but when I try to enter hard disk in XBMC there is a message disk not found. Prismcube does not see my internal hdd, when I connect it via usb it recognizes it, how to make it Prismcube see/mount my internal hdd?
Latest is:
FW 1.1.12
Format USB fat 32
Unzip & copy folder 'update_ruby' to root of usb drive
Insert usb and power on/off Prismcube
Prismcube will check image and install
Front display will let you know when to remove usb
Reboot
All the images have been good but 1.1.12 adds the most stability. I've not been able to crash the box at all. Works with various XBMC plugins e.g. Navi-X and others....
Latest is:
FW 1.1.12
Format USB fat 32
Reboot
Thx m8,
Where can I download it ?
Thanks for your quick reply, but how do you go about installing this version???
You are welcome. You can unstall it the same way as described by ekkostar.
Latest is:
FW 1.1.12
Format USB fat 32
Reboot
