Announcements All about PrismCube
I will be very grateful for any tips to solve the following issues:
1. when i watch sat the side parts of the screen cutted a little bit ,prismecube set to 1080p output , but when i am trying to calibrate the screen, xbmc shows resolution 1280*720 in calibration mode but the tv shows input 1080p.
2. i have a video delay (sat, youtube), even if i set the audio delay to maximum (250ms) it is not enough to sync between the sound and the picture.
3. the system freezes a lot , especially when i put it to sleep for a few hours, i cant turn it on (wake it up from sleep) by pressing a button on the remote, the led on prismcube blinking but nothing happen. so i need unplug it and plug it back to turn it on.
4. the fan set to automatic mode but it working at full rpm all the time even in sleep mode.
5. the network performance very slow , i cant play smoothly Blue-ray remux files over the network without lags , i tryed to copy a file from another pc using file manager and the результат was 4MB/s , compared to other (htpc with openelec) system i used before prismcube that was conected to the same wire and the speed was 35-40MB/s then.
6.cant find HDMI-CEC setting.
prismcube settings:
dolby audio - on
audio hdmi - spdif format
audio delay - 250ms
video output - hdmi
hdmi format - 1080p
tv screen format - normal pillarbox
hdmi color space - yuv
deep standby - off
fan control - automatic
prismcube with internal 500gb hdd conected to LG55LM860V with hdmi cable
Thanks in advance for your help.
What image version you are using?
@ all Bh testers.
Available Black Hole based on official 1.1.14 (For Beta testers only)
Changelog:
Add bh image version in issue.net (msg show when connecting in telnet)
Add Black Hole Ascii art in issue.net
update drivers
update maruapp
Added audio language auto selection list (SLOVAK, LAVBIAN, PERSIAN, etc )
Fixed bugs on multi-decrypt
Fixed bugs on CIModules
updated mr_lang ( fast scan )
edit : remove log epgevent
fix : FTI channel search bug in empty configured satellite system
edit : remove numbering, names control in fast scan menu
add : FTI channel search
debug - focused current channel
Update Provider.xml
Use presentation number
debug - speed up enter edit
edit : piddesc -> opdesc
edit : provider file path
edit : provider show name
add : fast scan operation
add : fast scan window
added multifeed icon image
support linkage service
@ all Bh testers.
Changelog:
update drivers
update maruapp
Update Provider.xml
Thanx a lot as u said u will give good news ,
thanx a lot, really good news willl wait and then will buy it,
regards
Confluence_BHP-0.0.2 Skin:
- MainMenu BlackPrism logo added
- removed RSS feed from PVR MainMenu ( you can deactivate the rss feed in settings too )
- MainMenu footer reduced
- MainMenu reversed
- MainMenu changed remote actions
- MainMenu position changed
- MainMenu color changed and added "no_focus" Item light at PVR & XBMC modus
- InfoBar changed shape color and ECM Icon color
- Changed PVR + XBMC Background
- ChannelList color changing for Programm Number ( focused and unfocused )
- ChannelList colors for Sidebar + PositionInfo + footer Info changed
- ... maybe something more, but I can't remember now...
@ all Bh testers.
Changelog:
update drivers
update maruapp
Update Provider.xml
Good news Shiro.
here is a new good reason to buy PrismCube.
By the way, what are conditions to become a beta tester?
- MainMenu reversed
wow
its really beautiful skin ,
i hope we will get BH soon ,
thanx for ur hard work
regards
. i do not have this problem at all
reinstall .may be will be the solution after factory reset
thanks
i did factory reset but the problem still exist, the most annoying is i cant turn on the device after a few hours of standby. the led blinking but the device doesnt turn on.
I KNOW THAT THE REMOTE IS ON TV MODE AFTER FEW HOURS .SO PUSH BUTTON NUM LOCK AND IT WILL BE DONE
THANKS
when the image is available, I expect this app to solve the problem of blockage???
EVEN WITH THE ACTUAL IMAGE I HAVE NO MORE BLOCKAGE
I SUGGEST YOU TO INSTALL VERSION 1.12 AND ALSO A HDD + THE FUSION XBMCHUB
YOU LL SEE LIKE ME NO MORE BLOCKAGE AS YOU SAY
Hi,
I've exact the same behavior as Vpekus.
After gone to standby i have to disconnect and connect the power cable to get the box to work again.
(Sometimes the box is not responding to the remote even when it's on.)
The FAN is "automatic" and in standby it turns fastest.
I have 1.1.12 as the image. I did a factory reset also ...
I hope this will be gone when i i'll do the next update ...
