Black Hole 3.0.2 Vu+ Solo2 Kodi
Nice, but look at how KODI appears on my screen :( it's a vu+ solo 2. is there any fix for that ?
Thank you.
For IPTV in general, do you recommend this image or open blackhole?
Thanks and keep up the great work
Dear all,
Can you help me please.
I have a VU+solo 2 flashed with this black hole. I don't have a parabolle (antenne) and so no signal. I'm using my solo2 for IPTV (provider RAPID IPTV).
Now my problem I can't set the date and the hours, by default it is 01/01/1970. I think for this reason I can't add also the EPG.
Thanks a lot.
I would kindly invite you to read our board rules, that you must already read when you join it, and you agree to follow them. --> http://www.vuplus-community.net/rules.html
It's not allowed by our board rules the discussion about implementing any kind of illegal stuff, as IPTV sharing service or CardSharing.
Time and date does not update unless connected to satelite. thats not problem with OBH image.ANY SOLUTION....LOVELY TEAM
Does Kodi's AirPlay work (on Solo SE)? If yes, must Kodi run (in the foreground) for AirPlay to work, or does it suffice to have the Kodi-AirPlay-Service running?
Since ever I am looking for an Solo SE Image that supports AirPlay...
Thx in advance!
+1 !!!! what's happening???
First of all thanks for the Image!
I've tried to change every possible configuration in Kodi continues in a 'window' instead full screen
I've tried to swicth off overscan in tv and Kodi continues in a 'windows instead full screen
BTW with OpenblachHole 0.4 I used Kodi in full screen without switching anything off... so it's not my TV or my Vu+Solo2 issue... it seems to be an image issue.
