Black Hole 3.0.2 Vu+ Solo2 Kodi
Hi, i have a big problem to me, with kodi and my solo2. I use a raspberry like server and when i try to view something from the lan (from the raspberry), kodi dont start the video... i try with smb, nfs, etc... but the video never start and the count are in 0:00.
Some idea please?
Of course, from my computers all work perfect.
(Apologies for my english.)
Hello,thank you for this image.
I have just a problem with Kodi : i have no sound,for music,movies,iptv just image.
In audio setting,i have no device detected,it's a bug?
Thank you.
Hello,
please could you confirm that the this version contains the last version (20151201) of the drivers for vu+ solose?
I'm having a problem with HD channels and I'm trying to solve the problem and I sow that the files in the 20151201 tar.gz files (vuplus-dvb-modules-vusolose-3.13.5-20151201.tar.gz) have different size from the ones I found in 3.0.2 F BH. I also tried to update the driver bui the decoder doesn't start.
Thank you
Hello,
Thank you
Confirm that in the latest BH, for Vu+SoloSE, the drivers are dated 2015-12-01.
Dear all, could you please tell me where I can find the BH 3.0.2,does it work onboard a cloud ibox3 Vu+?
thanks in advance-
Hi Matrix10, hope you can help. I have a used Vu+ Solo2 Open Blackhole image 0.6, please what Kodi version would be appropriate for this set? Where can I get this version - and what plug ins/add ons do I need to install? Thank you.
Kodi is supported in Open Black Hole 06 and the version is 16.1Rc2.
You can apply it in Black Hole Speed-Up Menu.
Press 2x Blue button and enable KODI.
Thanks for prompt reply. Should I download and install (FTP) or its already installed? I can see Kodi on the list of installed apps on my set but when I press OK on it, it does not open up?
First the latest Blackhole image is 3.0.3 N, so try using the latest version.
Second the Blackhole image is based on the vuplus official image, and I think they know how to code.
Before questioning the image I would check what addons you have added, if your receiver is genuine, and check if you have sufficient airflow, so that the receiver isn't over-heating.
Apart from that, Welcome to the Forum.
