Black Hole 3.0.2 Vu+ Solo2 Kodi
For those with time/date problems:
1. Install ******** in Options somewhere its change time/date manually,
2. In Terminal: date -s YYYY.MM.DD-hh:mm:ss
3. Learn a little system things and not just flash Image and change skins :)
Fucking third party panels like one you suggest to use are not welcome here because contains illegal materials.
For this reason you wn a week ban.
You need to turn off overscan on your tv.
eVO, I've turned off overscan on my TV and Kodi still in a quarter/screen little window... I had minutes ago OpenBH 0.4 with Kodi (isengard) in the same vuplus solo2 decoder plugged to the same TV and it worked so well in full screen... what's happening???
Thanks. Regards.
You have to set your screen settings, in kodi, this is not any issue in kodi, and not even in the builded image.
nunigaia, what screen settings in kodi?
I've tried to swicth off overscan in the TV, and of course to change screen settings in Kodi, but kodi still in a little quarter/screen window... so there's something wrong for sure; because I had minutes ago openBH with kodi (isengard) in the same TV and vu+solo2 decoder, and kodi worked OK, in full screen...
thnx. regards.
Thanks. Regards.
reading on the forum all have the same problem ... we hope in a team fix
so what is the solution fot timr and date update problem?'
thank you ANGELO BEST DRIVER
Connect to your box via telnet (I suggest to use the best Windows utility for that called PUTTY) and issue the command:
thanks, but it reverts back to 1970 when i do restart. i love bh and want to solve this bug..it does not happen open source.
there was plugin ntp for good old bn oe 1.6 but does not suit this new bh
Hi BH Team thank you for your work, i have the same problem,
kodi show up in a little quarter/screen window, but also Cool Tv Guide 7.30 show up in a little quarter/screen window.
Hope you find a way to fix.
Ciao
Blackhole 2.1.7
BlackHoloe 3.0.1F
OpenBlackHole 0.1
OpenBH 04
OpenSpa 5.0.0.5
OpenSpa 5.0.0.6
OpenPli 4.0
OpenATV 5.2
OpenATV 5.3
OpenVIX 3.2
OpenVIX 4.0
Vuplus Oficial image OE 3.0
BlackHole 3.0.2
Is this enough?
Have you Actually tried installed these images , and booted ok from external flash..????
I tried them all in kodi! the only way to full-screen kodi is set 720p in a/v settings of image bh ;) ... So there is some conflict between the skin or image and kodi settings i suppose! ;)
