Black Hole Vu+ Duo 1.7.0 Multiboot Full Backup
You can migrate your user data using Software Manager and it's backup function.
The Image upgrade is recommended because the box it's very fast and stable with new kernel 3.1.1.
Isn´t the kernel 3.1.1 alson in BH 1.66 ? I've tried to install BH 1.70 , but could not restore my back-up and the wifi doesn't work. So for me it's back to BH1.66. Regards
what ??? very fast and stable ????? something that i have missed here :) i think i is still as slow as before but still stable still owner of an dreambox 7000 that box was unstable
hey angelofsky when do you fix the wireless probs in the new image ???
so it doesent see all wifi as rt2800
BH 1.6.7/1.7.0 is stable. And it's not slow. Tested Solo and Duo and both boxes (as you know there are two frist boxes from Vu+) and both have gained performances.
About wifi issue: I've asked with BH coder and we are making changes into kernel and images to include the RT3070 driver instead of rt2800.
When I've ended some bugfix into USB DVB Tuner managment I will perform some tasks around wifi stack.
Kernel 3.1.1 DOESEN'T EXIST for old 1.6.6 Image.
About wifi: what stick do you have? It's already recognized by box?
Just installed the image and all seems good except that OpenVPN will not start. It works OK on 1.6.6 and before but on this is is always Stopped. I have the same configuration files and have set it active - any suggestions?
Update, just tried a BH 1.6.7 Beta and the OpenVPN works fine on that, so looks like something got changed between the beta and the release.
I'am usning a newer version of dlink dwa-140 H/W B2 F/W 1.71 the stick is having chipset rt3071
salut a tous et un grand merci pour le super travail que vous faite pour nous donne de tres belle images
hi
It seems that in the new image quality and resolution is low
i with previous image and videoenhancement i have beter than this resoletion image on my lcd sony
I restore the previous setting videoenhancement but my resoletion is not like previos image black hole !!!!
Nice work as usual, seems to work fine... Thx... :)
Just curious of one thing: Why do you change default skin in every release? Is it just something you have always done or is there other meaning behind it?
Regards,
BTJ
I use an ASUS WL-167g usb WLAN adapter
I have the Blackhole 1.6.6 and I'm REALLY SATISFIED.. At the Moment i don't have Problems, ALL WORKS FINE :)
REALLY THANKS TO ALL THE BLACKHOLE TEAM, AND AND ALL THE OTHERS, WHO WORKS WITH IT..
AWESOME BLACKHOLE.
Hi Guys
Glad to be back. I was away for a while and now back. I had BH 1.6.6 on flash and also on USB (Multiboot). Now I have installed the latest 1.7 in flash and want to install same on USB (Multiboot). How do I do that. Is it the same procedure - using DCC - FTP - media - usb - MbootM and then sent the USB Folder or the Zip file?
Tks for the assistance.
B/Rgds
Supermario
