Black Hole Vu+ Duo 1.7.2 (media-tree)
Thanks for the image guys, but i believe there is a bug when you choose the subtitle button, then it refers to the EleganceHD_P/menu/button640x25.png .
When you choose it througout the audio button it,s all ok, can someone test this please.
Test done,on BH 1.72 Vu Duo,,,, No bug,,,,every thing..is OK!
Thanks BH Team. Great image all the features I need work perfectly.
I encoutered a small problem with the tuner server.
I installed from scratch and added my bouquets manually.
When I start tuner server, the tuner directory is created on the HD but it is empty.
I found out that by default the system creates a bouquet named "fafourites (TV)" and that was the problem.
If you delete it, it will create a new one.
The solution is to edit the "userbouquet.favourite.tv" file and change the bouquet name by removing the "(" and ")".
No special symbols are allowed in bouquets names.
Can this be corrected in the next image?
This information may help other people too.
I experienced a crash ! Just regular watching. First watched an .MKV seemed OK, stopped it. back to TV and one zap and green screen.I use Advanced Movie Selection (never used before). I have never had this problem before on earlier images. Can it be AMS? Se crashlog.
Try without plugin ...
c'mon mate!!
you quote all those announcement just to reply with thanks
there is a button "like" under every post for such a thing
It seems to be a crash regarding AdvanceMovieSelection plugin... please try without it.
OK, I´ll try. Do you have any idea of a better plugin that do "the same" that is confirmed to work?
Try with EMC as release notes states "Fixed: Prevent crashes in plugins using infobar (double ok crash)"
Can someone confirm that EMC does work finally?
My hauppauge WinTv Mini stick is not automatically detected: with 1.7.1 I had no problem..it's a known issue or it's because I installed the image at 4.30 am because I couldn't sleep?!?
