Black Hole Vu+ Duo 1.7.2 (media-tree)
Thanks Rassi,
Signal is good, the issue is not coming from a poor signal. I will try a powered USB hub, hopefully this can solve.
Cheers
I´m not sure if it was that, which helped me with Sundtek sticks, after powered hub DVB-C has been stable, drivers has also updated so i do not know if hub was the key or not.
I do have second Sundtek connected also as DVB-T, but i havan´t used that much.
I did have same kind of issues with picture as in your video.
menu/setup/software management/manage extensions/network
Thanks. I installed it with 0 errors but though it opened on the Vu+ Home page, buttons not responding. The only response I get is moving up, down, right, left and Exit. Do I miss something or I have to do something else to browse.
Plugins such FORECA, IMDB, EMC are not shown on green panel after downloading from BH panel?
What is wrong?
Working fine now. I changed keyboard to event 0 instead of Remote Control. That left only Mouse on Remote Control and Web browser working fine now. Thanks all for your help.
yes i confirm too that web browser with that trick works fine...
thanks and regardsss..
im trying de new version blackhole 1.7.2. works fine! and my device usb tdt (a835) is recogniced but dont have signal when i search channel... what is the problem?
Hauppauge WinTV MiniStick here (Redi)
I restored the backup-settings-plugins-etc from 1.7.1 but DVB-T has dissapeared.
Also i cannot find the DVB-T tuner config menu to re-install the usb-stick.
At it's place i now see the 'Tuner Server' menu but as i understand is another thing.
Maybe switching back to 1.7.1 :(
Read HERE :)
What problem?
THE PROBLEM WHEN I FORMAT MY USB (sys linux)
i go to meoboot
and this msg apears
sorry it seems that there are not linx formattd devices mounted on your Vu+ to install meoboot you need alinx formatted part1 devic click on the green button to format your device
dnt show my usb
and no think happen
