I don't think that's it M8 as the Personal Backup didn't transfer from the Previous Kernel - I fully rebuilt from a clean BH1.7.2 a couple of days ago.
THE PROBLEM WHEN I FORMAT MY USB (sys linux)
i go to meoboot
and this msg apears
sorry it seems that there are not linx formattd devices mounted on your Vu+ to install meoboot you need alinx formatted part1 devic click on the green button to format your device
dnt show my usb
and no think happen
Working fine now. I changed keyboard to event 0 instead of Remote Control. That left only Mouse on Remote Control and Web browser working fine now. Thanks all for your help.
webbrowser dosen't work corretly, you can start it and exit and nothing else. can't write in url line can't start keyboard, can't access menu's = you can't do anything
so no use for webbrowser at this release.
I used webbrowser arora on my uno with BH 1.7.2. but the problem is that the free space in flash is very low, so i used a work around that solve the problem. I installed the 1.7.2. on the flash then with meoboot i installed the 1.7.2. on 2GB usb key with webbrowser and all the plugin a like and all work fine with no free space problem.
I am using BH 1.7.2 in Flash as well as in Meoboot. Now my problem is with CEC. I have a Sony Bravia LCD 40" EX400. The CEC was working fine with last image BH 1.6.6 installed on my DUO. Now with BH 1.7.2 I am having problem of wakeup - VU+duo as well as the TV. I have to use the back switch to turn the Duo as well as the TV = ON.
My CEC is as follows:-
HDMI CEC enabled : Yes
Set VU device name : VU+ Duo
Choose TV HDMI input : HDMI 1
Choose A/V Receiver HDMI input: No A/V receiver
TV on - > VU+ Activity: VU wakeup
TV standby => VU+ Activity: VU standby
VU on => TV activity: TV wakeup
VU Standby => TV Activity: TV Standby
VU deepstandby = > TV activity : TV Standby
TV Power ON:
TV power OFF:
Use TV remote control: Yes
Active Source reply on: Yes
Serial Log enabled: NO ( I even tried this option to Yes) but no luck
TV Power ON:
TV power OFF:
Did you tryed to change device with the left or right arrow?
If you did it and /media/usb/ didn't appeared, maybe your usb stick is not mounted by BH Devices Manager or it hasn't enough space to save the backup.
I have just downloaded and tested and I have 22 packages installed with no errors and it works.
Maybe you do not have enough free space for this plugin.
Try and install the package as soon as you install the image before you add any other plugin or file.
Strangely i went to Extensions Management in Software Management and it told me there are 21 updates!!!
Im with 1.7.2 but im not really sure and i havent click the update button... is BH do autoupdate?
The message you saw, says only there are updates available and not that you installed them.
Since this kind of updates may be incompatible with BH, you have to avoid to install them.
Hi
I have same situation, but when I press yellow button (update), nothing happened - ˝installed, upgraded or removed 0 packages with 0 errors˝.
Is it normal or something is wrong?
i have installed from software manager and it starts but doesn´t works correctly...the buttons don´t respond..could you try and confirm it? perhaps it is a problem only mine..
thankss BH team.
p.d. waiting for the HbbTV too ejjeejeeee...thanks a lot.
