Black Hole Vu+ Duo 1.7.2 (media-tree)
See post 125 for the crash log
Seems a YouTube problem ...
[MyTube] trying to find out if a HD Stream is available http://www.youtube.com/watch?v=EgT_us6AsDg&gl=US&hl=en
File "/usr/lib/enigma2/python/mytest.py", line 201, in processDelay
callback(*retval)
File "/usr/lib/enigma2/python/Plugins/Extensions/MyTube/plugin.py", line 514, in openMenu
myurl = myentry.getVideoUrl()
File "/usr/lib/enigma2/python/Plugins/Extensions/MyTube/MyTubeService.py", line 258, in getVideoUrl
fmt_infomap[int(fmtid)] = unquote_plus(fmturl)
ValueError: invalid literal for int() with base 10: '22,itag=84&url=http%3A%2F%2Fo-o.preferred.telenor-osl1.v2.lscache7.c.youtube.com%2Fvideoplayback%3Fsparams%3Did%252Cexpire%252Cip%252Cipbits%252Citag%252Csource%252Cratebypass%252Ccp%26itag%3D84%26ip%'
Can you see your usb stick in Device Manager?
Is it mounted?
Thanks to Mito & Ismirsat,
Problem now solved , usb was not mounted and now can be selected at Full Backup on BH panel.
Did notice that the usb needs to be free of backups or images because when you select usb in device manager, it needs to reboot, and if a backup or image
exists on usb then this will install at reboot.
Many thanks again guy's
love it just cant get epg to work on open or cross anyone having similier problems with this image,its a beuty apart from this epg problem..
CrossEPG works fine. Do you have it configured to store data on a USB or HDD? How many providers are you trying to get data for?
callback(*retval)
Are there anything i can do to fix this?
hello,
I have a vu + duo, holl black image, when I install the avatarcamd it does not appear on the cam, but the plugin is installed with anerror message at the bottom of the window.
for this purpose I ask you for help.
thank's in advance.
Ok fine!
Then its a "system" plug in issue!
Start with clean BH image!
When U re install the BH Personal Bkup,,,say NO to plug-ins installations!
Have Fun!
RgdZ
a911
I seem to have solved my Green Screen issue by generating a new swapfile. I've still not seen swapfile usage over 5% on this image with Ram use regularly over 95%, but at least it's stopped crashing.
I have installed the plugin Air Player 1.7 in BH 1.7.2 and it works perfectly, but on having executed the breeding animal makes me a crash whenever I execute it, if uninstall the plugin Airplayer everything works perfectly, has anybody proved it?
sorry for my english...
Thx
I'm starting to get a lot of Green screens now after the box has been online for several Hours. It happens when I try to look at the system info (Blue-Yellow) or devices manager (Blue-Blue). I also notice that the Swap file shows as inactive and will not activate and Hard Disk standby resets to 10 minutes (I had set it to 30 minutes before).
Yes, this is a problem that I noticed too. I got the error "Swap File creation Failed. Check for Available space." BlackHole Developers: Maybe a bug in BhSwap.py - possibly due to write to /tmp?
I fixed my problem by deleting and re-creating a 128Meg swapfile. There is still very little swapfile used with the RAM often being aver 95% full, so I suspect there is something in the swapfile utilization.
I do see this too. When I do not have swap files it was around 60% memory usage.
When I create a 256MB swapfile, it shows 95% memory usage and 0% swapfile usage.
