Black Hole Vu+ Duo 1.7.2 (media-tree)
I installed this image, and until now, no problem.
Seems is the best image.
I will try subtitles player in the futures by D.Damir because sometimes in older images crashes.
Thank you for ,BH TEAM.
Black Hole Vu+ Duo 1.7.2 (media-tree)​
The Black Hole 1.7.2 is the most "stable" and fast version of 3.1.1 releases.​
Based on Offilcial Vuplus image 7.0​
Kernel: 3.1.1​
Vuplus drivers: 20120126​
Vuplus DvbApp: 20120204​
MeoBoot: 1.0​
Skin: Army MooD HD updated​
NEW NEW NEW: Next generation Usb Tuner Drivers (media-tree bh build)​
Wifi drivers: rt3070 driver updated with some BH patches​
Fixed: Prevent crashes in plugins using infobar (double ok crash)​
Fixed: Vuplus WirelessLanSetup bug (Cannot generate Passphrase)​
Changelog Vu+ drivers: clean & speed up dmx driver​
Add gstreamer plugin fragmented​
Kernel: add igmp.patch​
Fix serviecmp3 bug: stop response timeout when stream is HLS.​
Fix youtube player of webbrowser launcher plugin: add code to select stream quality.​
NetworkSetup.py : fix checkNetworkCB function to prevent crash error​
HDMICEC : fix default device name​
Vuplus Event : input 7 SN_b for MSA​
Webbrowser: fix build bug.​
Changelog about USB DVB & Wifi Devices:​
- changed all set of DVB USB drivers: now with BH image there are the latest drivers available​
- USBTuner 0.3.9: a lot of bugfixes to improve stability and performances​
- Wifi (RT3070): applied some extra patches to Vu+ driver to improove dongle functions ​
WARNING: This Image has the latest drivers and CAN NOT be installed in multiboot.​
The image MUST be installed in the flash.​
Black Hole can not support images not installed in the flash.​
Please note that of all images Black Hole now has the best epg system:​
- Integrated OpenEpg​
- Rytec dedicated epg.dat​
- New system epg.dat outside.​
This last feature gives the possibility to various forums or communities to create their favorite EPG data files and load them into a web space.​
Community members can then download it from our servers.​
This feature provides other benefits such as:​
Increase download speed of EPG​
Download EPG from any channel​
Schedule the download of EPG decoder even during standby​
Users can customize the providers using Add / Remove function​
OK button = Skin with simple information​
OK button x 2 = Extra Info Skin​
Blue button = Black Hole Blue Panel​
Blue button and then Red button = Black Hole Epg Panel​
Blue button and then Yellow button = System Monitor Panel​
Blue button long press = Extensions​
Yellow button = Time Shift​
Green button = Black Hole Green Panel​
Green button long press = Subservices​
Green button and then Red button = Fast Plugin Setup​
Green button x 2 = Fast Plugin​
Button Red = Start Record​
Addons​
Green button and then Yellow button takes you to:-​
Dedicated server for BlackHole addons​
Download and install additional packages from the Black Hole server​
Infobar / OSD​
Analog Clock Gui​
Channel orbital location​
Advanced Tuner Info: Sr Freq Pol Fec​
Signal SNR, BER​
Infobar picons​
Characteristics of BlackHole Panels​
Blue Panel​
Extra Settings​
Black Hole Cron Manager (Manage schedules)​
OSD Settings (OSD configuration)​
Devices Manager​
Kernel Modules Manager(Kernel module operator)​
Inadyn Settings (Configure Inadyn)​
Swap File Settings (Configure File Swap)​
Hard Disk Settings (Configure Hard Drive)​
OpenVPN Panel ( OpenVPN Panel)​
Samba / CIFS Panel ( Samba Panel)​
NFS Server Panel ( NFS server Panel)​
Telnet Panel ( Telnet Panel)​
FTP Panel ( FTP Panel)​
UPnP Client Djmount​
UPnP Server Mediatomb​
Tuner Server​
Network Browse & Mountpoints​
Info Panel​
1 - Gui Setting (Gui configurations)​
2 - Service Information (information system)​
3 - About (info)​
Memory (Memory)​
Space (capacity)​
CPU (processor)​
Process (process)​
EPG Panel​
Global settings (global settings EPG)​
Setting Provider (ISP settings)​
Green Panel​
Addons (added)​
Addons Download Manager (Manager for package downloading)​
Installation manual packages (Manual installation of Black Hole packages)​
Manual Install IPK packages (Manual installation of IPK packages)​
Addons Uninstall Panel (Uninstalled packages)​
Black Hole Statistics (See connections, top downloads and more)​
Credits​
Thanks to Pedro_Newbie for Backup script​
Thanks to the group of Beta Testers.​
Thanks to Rytec for providing us with the server with all epg.dat files.​
Thanks to MaxZ4 for Integrated EPG loader.​
Thanks to Skaman for Cross EPG​
Thanks to Lukkino (VDR-Italy) for the source code of OpenTV.​
Thanks to Reinh@rd for the file satellites.xml.​
Thanks to ambrosa (Pli Board) for ready-to-go A867 driver patch​
DISCLAIMER​
THE BLACK HOLE IMAGE IS BASED ON THE OFFICIAL FIRMWARE PUBLISHED BY VU+ AND IN ACCORDANCE WITH THE LAW IT CONTAINS ONLY SYSTEM ADDITIONS & GRAPHIC CHANGES.​
LASTLY, THE BLACK HOLE IMAGE DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR ILLEGAL PURPOSES SUCH AS CARD SHARING.​
LICENSE (TERM OF USE)​
ANY CHANGES OR ADDITIONS TO BLACK HOLE IMAGE THAT INVOLVE UNLAWFUL USE OF THE IMAGE SUCH AS CARD-SHARING AND EMULATORS ARE NOT ALLOWED AND CAUSE THE REVOKE OF THIS LICENSE.​
This is free hobbyist software and it comes with absolutely no warranty. Use it at your own risk.​
Seems that this image working like a clock,but my missus pointed another thing which doesn't work:
When press + or - I get user/bouqet
Options 1-Epg search,2-Single epg,3-Multiepg,4Last serch-all not working.Rinstalled couple skins -no difference.It used to work on with older images.
Many thanks Blachhole Team
Are you sure ??
Look in Blue button>> Red >>Red>>Enable Epg Buttons in Channel list ...yes >>RED SAVE
Doese on vu+duo on BH 1.7.2 image have settings to make my 2 tuner to be loop to bi lnb out?becouse i have 1 more reciver to add on loop.
Hi all,
wifi RT5020 driver issues finally solved, thanks !
I am running this image since 1 week. So far I have noticed a slower channel list refreshing when scrolling down.
Seems a the system is not able (memory lack ?) to refresh quickly the list as a matter of fact that if you keep the "page down" button down (or you push quickly the button) on the remote controller, when you release it the list is still going down.
Thanks
Fab_
hello,
I haveavu+duo, hollblackimage, when I install the avatarcamhd it does not appearon the cam,butthepluginis installed withanerrormessageat the bottom ofthe window.
for this purposeI askyou for help.
thank's in advance.
hello,
thank's in advance.
Read the rules!!!!
On this board is not accepted to talk about emu.
Hi Team,
I have a small question about the remote control. I would have the advanced tuner info when pressing OK button x2 (signal SNR, BER,...) only when push 1 time as I like too much to have this extra info the first time I press OK button instead of 2 x. How can change this config.
Secondly, I want to protect all my parameters and config in order to avoid that the children change some thing without knowing it. How can I set this protection.
Thanks for your input,
Rogens150
VU+ Duo BH 172 HDD 1To
Hi Team,
Rogens150
1) 2X Blue> >OSD settings>setup (red)>,,,Disable Light Skin on Zap........Yes or NO,,,,,save (Red)
2)There is no total protection
But you can protect some options and panels in the Customize menu panel >> Setup Mode
So that is less options visible/hidden.
Option is most visible in expert mode. Restart Box after the change.
Hi Team,
Rogens150
1.
2xblue
osd setings
disable light skin on zap
2.
I dont know
Hi,
Openwebif: what port should I set as the defaulf is 00080 forHTTP? In my previous TVI 4 I had access directly to the remote and other options, now i have to open aother page to see it.
The free channel are displayed easily but the crypted ones no. Maybe some setting to do? Thanks for your availability.
Rogens150
Hi,
Rogens150
Port 8088
I dont have sound on Greece Nova HD chanels,i ask every people,and he tell me that problem for nova greece HD chanels is in enigma,can you chek thta?
hello use this image but I'm disappointed with it because the media center is a few simple functions, anyone know of a decent media center for the vu + duo, with options of subtitles, captions colors, sizes Subtitle someone can help me., obrigado ... edu
Have U tried some of the plugins that are avilable @ Image server!
I do not use media center, only AMC to watch movies!
