Black Hole Vu+ Duo 1.7.2 (media-tree)
Black Hole Vu+ Duo 1.7.2 (media-tree)​
The Black Hole 1.7.2 is the most "stable" and fast version of 3.1.1 releases.​
Based on Offilcial Vuplus image 7.0​
Kernel: 3.1.1​
Vuplus drivers: 20120126​
Vuplus DvbApp: 20120204​
MeoBoot: 1.0​
Skin: Army MooD HD updated​
NEW NEW NEW: Next generation Usb Tuner Drivers (media-tree bh build)​
Wifi drivers: rt3070 driver updated with some BH patches​
Fixed: Prevent crashes in plugins using infobar (double ok crash)​
Fixed: Vuplus WirelessLanSetup bug (Cannot generate Passphrase)​
Changelog Vu+ drivers: clean & speed up dmx driver​
Add gstreamer plugin fragmented​
Kernel: add igmp.patch​
Fix serviecmp3 bug: stop response timeout when stream is HLS.​
Fix youtube player of webbrowser launcher plugin: add code to select stream quality.​
NetworkSetup.py : fix checkNetworkCB function to prevent crash error​
HDMICEC : fix default device name​
Vuplus Event : input 7 SN_b for MSA​
Webbrowser: fix build bug.​
Changelog about USB DVB & Wifi Devices:​
- changed all set of DVB USB drivers: now with BH image there are the latest drivers available​
- USBTuner 0.3.9: a lot of bugfixes to improve stability and performances​
- Wifi (RT3070): applied some extra patches to Vu+ driver to improove dongle functions ​
WARNING: This Image has the latest drivers and CAN NOT be installed in multiboot.​
The image MUST be installed in the flash.​
Black Hole can not support images not installed in the flash.​
Please note that of all images Black Hole now has the best epg system:​
- Integrated OpenEpg​
- Rytec dedicated epg.dat​
- New system epg.dat outside.​
This last feature gives the possibility to various forums or communities to create their favorite EPG data files and load them into a web space.​
Community members can then download it from our servers.​
This feature provides other benefits such as:​
Increase download speed of EPG​
Download EPG from any channel​
Schedule the download of EPG decoder even during standby​
Users can customize the providers using Add / Remove function​
OK button = Skin with simple information​
OK button x 2 = Extra Info Skin​
Blue button = Black Hole Blue Panel​
Blue button and then Red button = Black Hole Epg Panel​
Blue button and then Yellow button = System Monitor Panel​
Blue button long press = Extensions​
Yellow button = Time Shift​
Green button = Black Hole Green Panel​
Green button long press = Subservices​
Green button and then Red button = Fast Plugin Setup​
Green button x 2 = Fast Plugin​
Button Red = Start Record​
Addons​
Green button and then Yellow button takes you to:-​
Dedicated server for BlackHole addons​
Download and install additional packages from the Black Hole server​
Infobar / OSD​
Analog Clock Gui​
Channel orbital location​
Advanced Tuner Info: Sr Freq Pol Fec​
Signal SNR, BER​
Infobar picons​
Characteristics of BlackHole Panels​
Blue Panel​
Extra Settings​
Black Hole Cron Manager (Manage schedules)​
OSD Settings (OSD configuration)​
Devices Manager​
Kernel Modules Manager(Kernel module operator)​
Inadyn Settings (Configure Inadyn)​
Swap File Settings (Configure File Swap)​
Hard Disk Settings (Configure Hard Drive)​
OpenVPN Panel ( OpenVPN Panel)​
Samba / CIFS Panel ( Samba Panel)​
NFS Server Panel ( NFS server Panel)​
Telnet Panel ( Telnet Panel)​
FTP Panel ( FTP Panel)​
UPnP Client Djmount​
UPnP Server Mediatomb​
Tuner Server​
Network Browse & Mountpoints​
Info Panel​
1 - Gui Setting (Gui configurations)​
2 - Service Information (information system)​
3 - About (info)​
Memory (Memory)​
Space (capacity)​
CPU (processor)​
Process (process)​
EPG Panel​
Global settings (global settings EPG)​
Setting Provider (ISP settings)​
Green Panel​
Addons (added)​
Addons Download Manager (Manager for package downloading)​
Installation manual packages (Manual installation of Black Hole packages)​
Manual Install IPK packages (Manual installation of IPK packages)​
Addons Uninstall Panel (Uninstalled packages)​
Black Hole Statistics (See connections, top downloads and more)​
Credits​
Thanks to Pedro_Newbie for Backup script​
Thanks to the group of Beta Testers.​
Thanks to Rytec for providing us with the server with all epg.dat files.​
Thanks to MaxZ4 for Integrated EPG loader.​
Thanks to Skaman for Cross EPG​
Thanks to Lukkino (VDR-Italy) for the source code of OpenTV.​
Thanks to Reinh@rd for the file satellites.xml.​
Thanks to ambrosa (Pli Board) for ready-to-go A867 driver patch​
DISCLAIMER​
THE BLACK HOLE IMAGE IS BASED ON THE OFFICIAL FIRMWARE PUBLISHED BY VU+ AND IN ACCORDANCE WITH THE LAW IT CONTAINS ONLY SYSTEM ADDITIONS & GRAPHIC CHANGES.​
LASTLY, THE BLACK HOLE IMAGE DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR ILLEGAL PURPOSES SUCH AS CARD SHARING.​
LICENSE (TERM OF USE)​
ANY CHANGES OR ADDITIONS TO BLACK HOLE IMAGE THAT INVOLVE UNLAWFUL USE OF THE IMAGE SUCH AS CARD-SHARING AND EMULATORS ARE NOT ALLOWED AND CAUSE THE REVOKE OF THIS LICENSE.​
This is free hobbyist software and it comes with absolutely no warranty. Use it at your own risk.​
like this.
I try to flash my Vu+Duo with usb stick,when I reboot its only stay Vu+Duo in display and nothing more happens. What could be wrong?
Display or TV ??
Have you chosen correct HDMI port to which receiver is connected ??
Have you unplugged USB stick ??
guys i need help, i am struggling to create a mount from my PC using this image, someone got a step by step guide on what i need to do as i have been trying for long with not working. When i click on browse network i can see my laptop but when i expand i cant see anything, i have created a share so i should see somethingt but i cant. I am using windows 7 machine.
got it working now seems like i was having issues as i had a HDD in there already, either if i changed the path for it or removed it all working fine now.
I have flashed with latest BH image, but picture looks horrible on HD channels, there's lot of horisontale stripes. TV is HD ready and HD channels has looked fine with others images. I think there must be some kind of driverproblem.
Stupid me, I had not connected the signal to tv, sorry
We need more inf regarding the settings , connection and configuration?
plus to have clear HD reception , the SAT signals should be SNR>50 %!
And screen shot of TV pictures , will give us more info about the problem!
However, if you are happy with other images, U can use them!
BH image has nothing to with the issue U'r (only) having!
GdLuck!
a911
GdLuck!
a911
I see is depend witch channels I use. Some channels are wors than others. I don't know how to take screenshot from my tv, but if there's a 45 degrees line on tv, this line looks like a stairs with steps and not a fine stretch line. Signals is over 70% and I have not changes settings on tv or my sat receiver.
Of course if I not find any solution about this problem I must try another image. I have never had problem with earlyer vers of BH images.
For screenshot,
@U"r PC,, put the STB IP at your net browser , and you will have wep-if ,,displayed ( read a little pit more about this here in the forum,,or Google for more details)
However , as you explain, it may be a TV issue or settings configarations!
Here is my settings for example:-
Or try other images , and see!
GdLucK
a911
This image is sublime will have one problem when the sound does not work on some tv channel so you have to reboot to make it work.
This image issublimewill have oneproblemwhenthe sounddoes not work onsometvchannelso you have torebootto make it work.
This an isolated case,that is happening to your STB, and nothing to do w/BH Image!
Please ,can U give more info!
On 1.7.2 the option to set a channel as default startup service is missing.
Was this eliminated or moved somewhere else in the menu ?
I can not remember the options channel as default startup within the image.
There is only a plugin for it on the server StartUPService I think
But I did not test .
