Black Hole Vu+ Duo 1.7.2 (media-tree)
I dont have sound on Greece Nova HD chanels,i ask every people,and he tell me that problem for nova greece HD chanels is in enigma,can you chek thta?
How I found out on the Net , the problem is that the channels are scrambled.
But we asked VU to investigate this problem.
If anyone has more information (and have test)
they are welcome
they are welcome
the problem is as well with the free hd ones
is fine just if contains only the osd
1.7.2 and duo
for sure a dvb-t one la7hd give that error (i notified it yesterday)
with the grab command:
just the
grab -j 100 /tmp/shot1.jpg (full one, answer with a segfault)
with -o (osd) and -v (screen) works
free hd ones ?? Which One.
No process of screen shot will not be completed!
If I took SS on Free HD ,,,I can see the complete shot on the Wep-If ,,,,but when safed on my PC,,,only vidoe shot will show up NO osd!
Luxw.tv on 26E.
May be something to do with HD resolution!
right now:
einsfestival hd all fine with and without osd
a dvb-t free hd one , answer with a segfault
i haven't noticed that difference before, sorry for the bad report :)
just the
Not with all HD formats
1920x1080 bad
1440x1080 OK
1280x720 OK
I have just upgraded from BH 1.6.5 to BH 1.7.2 and now i can not get my usb WIFI dongle to work.
The dongle is an D-link DWA140 (chipset RT2870 i think). Is this dongle supported or not?
Hello, anybody there?
When i try to configure wifi using WEP2 i get error message "can Not generate passphrase". Didn't you say this was fixed?
Is this dongle supported or not? And if not, when will it be supported?
First of all change the SSID name of your wifi network with a simplest one.
If you see the wifi configuration, the dongle is correctly detected.
For other help, please post in correct section.
Doese on vu+duo on BH 1.7.2 image have settings to make my 2 tuner to be loop to bi lnb out?becouse i have 1 more reciver to add on loop.
No not possible...:sad:!
Yes there is option, but I didn't test it.
menu/setup/service searching/tuner configuration/tuner B/looptrough to tunerA
i add that and not worke,i tourn off vu+duo,and second reciver not get signal froom loop,
