Black Hole Vu+ Duo 1.7.2 (media-tree)
hello
BH 1.72 all right very well but why i can't install in multiboot vti 4.1 ? last drivers 21 01 2012 for us, why it's not possible ?
Thanks all.
Black Hole Vu+ Duo 1.7.2 (media-tree)​
The Black Hole 1.7.2 is the most "stable" and fast version of 3.1.1 releases.​
Based on Offilcial Vuplus image 7.0​
Kernel: 3.1.1​
Vuplus drivers: 20120126​
Vuplus DvbApp: 20120204​
MeoBoot: 1.0​
Skin: Army MooD HD updated​
NEW NEW NEW: Next generation Usb Tuner Drivers (media-tree bh build)​
Wifi drivers: rt3070 driver updated with some BH patches​
Fixed: Prevent crashes in plugins using infobar (double ok crash)​
Fixed: Vuplus WirelessLanSetup bug (Cannot generate Passphrase)​
Changelog Vu+ drivers: clean & speed up dmx driver​
Add gstreamer plugin fragmented​
Kernel: add igmp.patch​
Fix serviecmp3 bug: stop response timeout when stream is HLS.​
Fix youtube player of webbrowser launcher plugin: add code to select stream quality.​
NetworkSetup.py : fix checkNetworkCB function to prevent crash error​
HDMICEC : fix default device name​
Vuplus Event : input 7 SN_b for MSA​
Webbrowser: fix build bug.​
Changelog about USB DVB & Wifi Devices:​
- changed all set of DVB USB drivers: now with BH image there are the latest drivers available​
- USBTuner 0.3.9: a lot of bugfixes to improve stability and performances​
- Wifi (RT3070): applied some extra patches to Vu+ driver to improove dongle functions ​
WARNING: This Image has the latest drivers and CAN NOT be installed in multiboot.​
The image MUST be installed in the flash.​
Black Hole can not support images not installed in the flash.​
Please note that of all images Black Hole now has the best epg system:​
- Integrated OpenEpg​
- Rytec dedicated epg.dat​
- New system epg.dat outside.​
This last feature gives the possibility to various forums or communities to create their favorite EPG data files and load them into a web space.​
Community members can then download it from our servers.​
This feature provides other benefits such as:​
Increase download speed of EPG​
Download EPG from any channel​
Schedule the download of EPG decoder even during standby​
Users can customize the providers using Add / Remove function​
OK button = Skin with simple information​
OK button x 2 = Extra Info Skin​
Blue button = Black Hole Blue Panel​
Blue button and then Red button = Black Hole Epg Panel​
Blue button and then Yellow button = System Monitor Panel​
Blue button long press = Extensions​
Yellow button = Time Shift​
Green button = Black Hole Green Panel​
Green button long press = Subservices​
Green button and then Red button = Fast Plugin Setup​
Green button x 2 = Fast Plugin​
Button Red = Start Record​
Addons​
Green button and then Yellow button takes you to:-​
Dedicated server for BlackHole addons​
Download and install additional packages from the Black Hole server​
Infobar / OSD​
Analog Clock Gui​
Channel orbital location​
Advanced Tuner Info: Sr Freq Pol Fec​
Signal SNR, BER​
Infobar picons​
Characteristics of BlackHole Panels​
Blue Panel​
Extra Settings​
Black Hole Cron Manager (Manage schedules)​
OSD Settings (OSD configuration)​
Devices Manager​
Kernel Modules Manager(Kernel module operator)​
Inadyn Settings (Configure Inadyn)​
Swap File Settings (Configure File Swap)​
Hard Disk Settings (Configure Hard Drive)​
OpenVPN Panel ( OpenVPN Panel)​
Samba / CIFS Panel ( Samba Panel)​
NFS Server Panel ( NFS server Panel)​
Telnet Panel ( Telnet Panel)​
FTP Panel ( FTP Panel)​
UPnP Client Djmount​
UPnP Server Mediatomb​
Tuner Server​
Network Browse & Mountpoints​
Info Panel​
1 - Gui Setting (Gui configurations)​
2 - Service Information (information system)​
3 - About (info)​
Memory (Memory)​
Space (capacity)​
CPU (processor)​
Process (process)​
EPG Panel​
Global settings (global settings EPG)​
Setting Provider (ISP settings)​
Green Panel​
Addons (added)​
Addons Download Manager (Manager for package downloading)​
Installation manual packages (Manual installation of Black Hole packages)​
Manual Install IPK packages (Manual installation of IPK packages)​
Addons Uninstall Panel (Uninstalled packages)​
Black Hole Statistics (See connections, top downloads and more)​
Credits​
Thanks to Pedro_Newbie for Backup script​
Thanks to the group of Beta Testers.​
Thanks to Rytec for providing us with the server with all epg.dat files.​
Thanks to MaxZ4 for Integrated EPG loader.​
Thanks to Skaman for Cross EPG​
Thanks to Lukkino (VDR-Italy) for the source code of OpenTV.​
Thanks to Reinh@rd for the file satellites.xml.​
Thanks to ambrosa (Pli Board) for ready-to-go A867 driver patch​
DISCLAIMER​
THE BLACK HOLE IMAGE IS BASED ON THE OFFICIAL FIRMWARE PUBLISHED BY VU+ AND IN ACCORDANCE WITH THE LAW IT CONTAINS ONLY SYSTEM ADDITIONS & GRAPHIC CHANGES.​
LASTLY, THE BLACK HOLE IMAGE DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR ILLEGAL PURPOSES SUCH AS CARD SHARING.​
LICENSE (TERM OF USE)​
ANY CHANGES OR ADDITIONS TO BLACK HOLE IMAGE THAT INVOLVE UNLAWFUL USE OF THE IMAGE SUCH AS CARD-SHARING AND EMULATORS ARE NOT ALLOWED AND CAUSE THE REVOKE OF THIS LICENSE.​
This is free hobbyist software and it comes with absolutely no warranty. Use it at your own risk.​
Unfortunately I have to delete the shot/pictures
because it violates the forum rules regarding the EMU.
So pls without such a screen shots.
I would ask you to continue the test, because I have no opportunity to test Nova HD channels.
So is these audio working or not ??
Sorry to put on a screenshot
Nova HD channels No Sound
I have no Nova HD package to test.
Ok, to hear other members with the Nova HD package
that we were 100% sure that the problem exists
because HD satellite channels on similar freq from other providers
work for me without problems.
Kernel: 3.1.1​
MeoBoot: 1.0​
Addons​
Infobar / OSD​
Analog Clock Gui​
Signal SNR, BER​
Infobar picons​
Blue Panel​
Extra Settings​
Devices Manager​
Tuner Server​
Info Panel​
3 - About (info)​
Memory (Memory)​
Space (capacity)​
CPU (processor)​
Process (process)​
EPG Panel​
Green Panel​
Addons (added)​
Credits​
DISCLAIMER​
hi buddy have a question but need to pm thanks bb
@blue there is nothing you need to pm admin about regarding image support, that is why we have an open board.
If Lorenzo is your personal friend then I am sure you have other means of contact, I have also removed you obnoxious remark from the shout box.
@Artorious ...it wasn't meaning to be obnoxious like his reply!! all i asked was for some HELP and didn't want to get myself in trouble for asking a sensitive question on forum...? as thats what i thought we were all here for to HELP each other ... so i'm sorry for bothering you guys and i,ll just keep searching for the answer thank you
Members have to understand we are not here to support some of the sensitive subjects, there really are hundreds of boards that can and do assists in these areas.
The team here really have their time cut out with the image support.
Thanks for understanding.
is that possible to trancode webradio to mp3 format using mediatombs scripts on vu+duo and if answar is yes how to get it.
picture in picture in not work
in this black hole when i choose it nothing for show
