Black Hole Vu+ Duo 1.7.2 (media-tree)
I experienced a crash ! Just regular watching. First watched an .MKV seemed OK, stopped it. back to TV and one zap and green screen.I use Advanced Movie Selection (never used before). I have never had this problem before on earlier images. Can it be AMS? Se crashlog.
OK, i have to try this plug.
I use EMC.
My hauppauge WinTv Mini stick is not automatically detected: with 1.7.1 I had no problem..it's a known issue or it's because I installed the image at 4.30 am because I couldn't sleep?!?
Your stick is currently supported.
Please remove all other USB devices...
Do I need to update DUO_CFE prior to go to this BH 1.7.2? Currently I have BH experimental from April 2011. Thank you
If you haven't installed any recent image after 1.6.7 you don't need to update Duo CFE.
I suggest to update the CFE.
Thank you, just another question: if I want to install two USB Dtt supported devices what I might do? Do I put them together in the USB hub or must I install one and then the other?
Connect both.
If all works correctly they appear in the Tuner Configuratino panel.
Just installed, updated from 1.7.1 using personal backup for the first time. What a fantastic time saver, image up in 15 mins and very little manual steps required, great!!!!!!!!!!!!!
Now hopefully DVB-T has improved, will report back after a few days testing.
Really like the new spinner!
Thanks!!
Try to download from software manager.
i have installed from software manager and it starts but doesn´t works correctly...the buttons don´t respond..could you try and confirm it? perhaps it is a problem only mine..
thankss BH team.
p.d. waiting for the HbbTV too ejjeejeeee...thanks a lot.
Hauppauge WinTV MiniStick here (Redi)
I restored the backup-settings-plugins-etc from 1.7.1 but DVB-T has dissapeared.
Also i cannot find the DVB-T tuner config menu to re-install the usb-stick.
At it's place i now see the 'Tuner Server' menu but as i understand is another thing.
Maybe switching back to 1.7.1 :(
Redi PC100.
Tried factory defaults and manual setup, still not recognized in tuners.
Back to good old 1.7.1 , working fine :(
Thanks!!
DVB-T still broken with Avermedia A867, see attached video. It's probably a bit worse than 1.7.1. It used to work fine for about 48 hours. Today I flashed 1.7.2 at about 3PM and this evening DVB-T stopped working. Same buffering, video goes in a loop issue, video speaks for itself.
Thanks a lot Angelo for all your efforts. As a matter of interest, is DVB-T working correctly on Ultimo?
Cheers
Cheers
Are you sure about your signal? It is good?
Have you tested it with powered USB-hub?
Thanks Rassi,
Signal is good, the issue is not coming from a poor signal. I will try a powered USB hub, hopefully this can solve.
Cheers
